PC HElp Wireless etc
Old Nov 3, 2004 | 01:30 PM
BigNige's Avatar
BigNige
Default PC HElp Wireless etc
Gents and Ladies
I need advice on what kit i would need to buy in terms of getting my office at home on wireless network etc
Must be able to use for broadband with AOL
Dosent have to be the BEST in the world
Just want a reasonable speed on the net
Ability to use it on my PC and LAPTOP around the house
Any thoughts
I know Ebuyer for prices but what KIT do i need in terms of EVERYTHING
Thanks
NIge
Old Nov 3, 2004 | 01:41 PM
stuart_r_g's Avatar
stuart_r_g
i got wireless router from maplins, cost 100quid and get a laptop card and pc card and use it around the house. i got one because we can use 4 pcs at a time at my uni house.
Old Nov 3, 2004 | 01:43 PM
BigNige's Avatar
BigNige
so maplins it is
the oruter can be used for broadband too ??
PC newbie
nige
Old Nov 3, 2004 | 01:46 PM
Jonzy's Avatar
Jonzy
Ive just picked up a belkin wireless router and nic for 70 quid delivered. Simply and ebuyer.
Pretty much all you need.
Old Nov 3, 2004 | 01:48 PM
stuart_r_g's Avatar
stuart_r_g
our one runs with ntl broadband so should be fine.
Old Nov 3, 2004 | 01:54 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
BigNige,
I take it you already have an AOL supplied router or something like that at the moment, one that plugs into the wall (RJ-11 connection) and at the back of your PC (either RJ-45 or USB).
A Wireless DSL Router will have a cable coming out of it which you plugs into the wall where the AOL one used to go.
The router will make the ADSL line available over a wireless network.
Make sure YOU DON'T get a Wireless Access point, because this has nothing to do with ADSL and only provides wireless access into an existing wired network.
Once you have the Wireless DSL router up and running, you should be able to get onto the net using a wireless card in your pc/laptop.
Note: Check with AOL that you can actually do this, not just contractually (who cares about that), but technically, there may be router settings that AOL won't provide you with, hence preventing you from using the router altogether.
If you are not sure about all this, it may be best calling DSL Source (www.dslsource.co.uk) on 0870 600 33 32, they will more likely than not know about the specifics of AOL, etc... and will be able to advise on the best hardware to get.
I say this, cos it may be necessary to get a wireless router than plugs into the box you already have rather than straight into the wall, etc...
Good luck - I dunno what level of technical knowledge you have, so I tried to explain this in layman's terms, it that not good enough let me know and I'll try again
Old Nov 3, 2004 | 01:57 PM
frog's Avatar
frog
Also, just found this (bored at work ) you might find useful.
http://forums.broadbandbuyer.co.uk/f...=1150&get=last
Do a search in their Wireless / WiFi forum for AOL.
Note: That AOL do not support Wireless, so calling them about it will be pointless...
Old Nov 3, 2004 | 03:01 PM
Ish's Avatar
Ish
i got a broadband router , wireless card for laptop & wireless card for pc for about Ł80 from www.ebuyer.com
Old Nov 3, 2004 | 03:11 PM
BigNige's Avatar
BigNige
Thanks for the help specially the "frog"
Nige
Old Nov 3, 2004 | 04:17 PM
frog's Avatar
frog
No worries nige (real name is Greg btw).
Good luck
Thrush
Computers, Consoles and I.T.
Oct 19, 2005 03:24 PM
Snowy_Astra
Sep 29, 2005 04:03 PM
Gra
11
Aug 13, 2005 01:45 PM
BigNige
Nov 20, 2004 12:02 AM
Turbo lag
Sep 6, 2004 06:57 PM
