Engine tuning Stage x
could someone explain the basics of,
Stage 1
Stage 2
Stage 3
stage 15???
what is generally done to the engine to progress from one 'stage' to the next.
cheers in advance.
Stage 1
Stage 2
Stage 3
stage 15???
cheers in advance.
Generally, for cossies the accepted stages are:
1) 270-280 BHP 15-16psi ish, chip and -31actuator change
2) 300ish, light green injectors (355's) 18-20psi chip and -31actuator change, rare now as most people go to stg 3 immediatly.
3) 330ish BHP, dark greens 3 bar map sensor -31 actuator.
Stg 3 is quite an open statement as you can run dark greens on a T3 or a T34, rs500 cooler etc so a wide range of specs under the stg 3 umbrella.
basically its made up so it doesnt mean shit
but as wil has bosted thats what people normally mean when theyre talking cossies.
i tend to think of "stage1" on any car as exhaust/chip/filter but like i said, its all made up by companies to sound good so i wouldnt beleive much
Many of the cars are way past the 'basic' stage 1,2,3.
I thought I was a bit backward asking, but from everyones comments, it's a lot clearer now.
cheers.
mark, are each of your "stages" set in stone tho with each gradualy improving on the previous? or did you just kinda throw together a pricelist that looks sensible?
Its only when you get to the higher spec's that the price creeps up but each one has to be priced rather than a set cost as parts and other bits can add or take away on the total price.
Mark
http://www.apra70.dsl.pipex.com/home/index.htm click on ford (left), then click on the far right what cossie, all the stages are there
Mark
would you say that the exhaust system was still a restriction on all your modded engines, or has this necessary part been improved so much that it does not detract from the final results.
If you had a free hand with the exhaust system, could you improve on your results.
Mark
Mark
big_Rad
15-09-2017 09:36 AM
