Uprated rear diff hanger fitting problem
Old Jul 16, 2008 | 10:37 PM
Rippers's Avatar
Rippers
Monte Geek
Default Uprated rear diff hanger fitting problem
Has anyone else had a problem fitting up one the uprated diff hangers on a Esc Cos.. mine fowls the ARB
Any suggestions as to what I'm doing wrong?? I tried turning the ARB upside down to see if it was shaped differently, made no difference
It's a 7'5" diff in a Ahmed beam but I can't see how that would make a difference as the mount and the ARB bar mount to the chassis,
Only thing I can come up with is maybe my mount is for a Sierra with the skinny ARB?? other then that I'm stumped
Old Jul 16, 2008 | 10:54 PM
abdr500's Avatar
abdr500
mine all so i used a differnt bolt just to clear
Paul_RS's Avatar
Paul_RS
I fitted one to my 4x4 sapph and had no clearance issues? that just with the standard 7" diff.
Although i have heard of people having to gring down bolt heads before due to the arb hitting them.
Old Jul 16, 2008 | 11:52 PM
Kelv's Avatar
Kelv
Almost there!
ive heard exactly the same.
as as above has mentioned, bolts have been ground down to suit, or slimmer headed bolt used.
yet to fit up my anti-roll-bar so havent had this issue.
Old Jul 16, 2008 | 11:58 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Odd, I bought mine off GGR and it fits the rear fine, Danny B rear beam....
Old Jul 17, 2008 | 12:25 AM
STUCOS's Avatar
STUCOS
Remember escos arb a lot thicker than saff one,there for sits closer to diff
cheeRS stu
Old Jul 17, 2008 | 12:40 AM
xr4x4rs's Avatar
xr4x4rs
got one on mine, and i had to grind the top bolt to clear my roll bar
the pic looks like its touching but it isnt, and you can see how much mine had to go
Old Jul 17, 2008 | 05:18 AM
wes's Avatar
wes
Is that with the rear wheels off the floor? I noticed this too on mine, but when the wheels are back on the floor it doesn't foul as the suspension is in it's normal position and not at full travel.
Old Jul 17, 2008 | 05:31 AM
JHS's Avatar
JHS
Had the same problem on my friends Escort with standard rear diff and beam as well...
Old Jul 17, 2008 | 06:26 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
exactly the same on my saff
dont know what you are supposed to do about it. pisses me off tbh
im using the standard anti roll bar still but i want to get an escos one
Old Jul 17, 2008 | 06:35 AM
If you can't find an escos rear roll bar you can use a SCORPIO Cossie(saloon) rear roll bar, just 1mm thinnner that's all, must be from the BUG EYE scorpio though.
Just about to fit mine, should be fun then!!
Old Jul 17, 2008 | 07:19 AM
CossieRich's Avatar
CossieRich
Tab,
let us know how you find it and the difference you experience mate
Old Jul 17, 2008 | 08:05 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
It seems very hit and miss, some have issues touching and some don't (good old Ford tolerances ). Obviously it is more likely to need a tweek with the larger ARBs, but I somehow got away with out it on mine, yet others with even the smaller ARBs have needed a different bolt or grinding some material off.
Old Jul 17, 2008 | 08:06 AM
CossieRich's Avatar
CossieRich
SO if i get an escos roll bar i have no chance of getting the bolt in the rear hanger to fit at all have i
Old Jul 17, 2008 | 08:12 AM
Mike Rainbird
Caraholic
As Wes has said, I only think it is an issue on full droop . It "may" be more prevalent with a standard beam though?
Old Jul 17, 2008 | 09:23 AM
Rippers's Avatar
Rippers
Monte Geek
I found this bit of information last night from the manufacturers
Note that while the vast majority of Escort Cosworth owners had no trouble installing this mount on their vehicles, there have been a couple owners that mentioned the rear sway bar needs to be adjusted rearward a bit to clear this mount. One owner filed down the lower diff mount bolt head a bit to solve the problem. If you are purchasing this mount to install on an Escort Cosworth, please understand that you may have to adjust your rear sway bar to complete the installation, or clearance the diff mount bolts. Sierra and XR4Ti owners need not concern themselves with this, as the mount fits perfectly in all situations.
Damn yanks
Old Jul 17, 2008 | 09:31 AM
NEIL A's Avatar
NEIL A
Never had any clearance problems with mine
Old Jul 17, 2008 | 11:16 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Where did you get the mount from ?
Steve.
Old Jul 17, 2008 | 11:37 AM
Mike Rainbird
Caraholic
http://www.randbmotorsport.co.uk/sho...?ProductID=298
In stock, ready to roll .
Old Jul 17, 2008 | 12:13 PM
CossieRich's Avatar
CossieRich
In stock, ready to sit on your anti roll bar .
Old Jul 17, 2008 | 12:14 PM
Kelv's Avatar
Kelv
Almost there!
Old Jul 17, 2008 | 12:20 PM
xr4x4rs's Avatar
xr4x4rs
you carnt adjust the rear bar though, its all on fixed points
Old Jul 17, 2008 | 12:25 PM
Mike Rainbird
Caraholic
Don't worry, it only touches on ARBs on idiot's cars .
Old Jul 17, 2008 | 12:27 PM
Kelv's Avatar
Kelv
Almost there!
phew, thats lucky then, i was wondering if mine was likely to touch when i fit it up.
at least i know mine will be ok then - i think
Old Jul 17, 2008 | 12:30 PM
Mike Rainbird
Caraholic
Yours will touch on BOTH bolts .
Old Jul 17, 2008 | 12:42 PM
Warren's Avatar
Warren
Paul you bufty!!
I recall mine was a bit snug, but it wasn't rubbing. I'm sure when you assemble the bushes this had something to do with it. I'm probably wrong but I remember David saying if theres a wrong way I'll do it first and it was a few months ago
Old Jul 17, 2008 | 01:02 PM
Rippers's Avatar
Rippers
Monte Geek
Steve.
Someone off here can't honestly remember who, he had imported it from the US but never got around to fitting it.
Glad I'm not the only one with probs with this mount, silly design but I guess you don't get many Esc Cos's in the US
Old Jul 17, 2008 | 01:08 PM
Rippers's Avatar
Rippers
Monte Geek
Warren I tried everything took the ARB off turned it upside down, re-adjusted the ARB mounts re adjusted the diff mount just a poor design that should suit all without mods IMO but I guess I'm just an idiot eh Mike?
Old Jul 17, 2008 | 01:14 PM
Warren's Avatar
Warren
Paul I'd never tar you with that brush, Mike just takes its to a whole new level
Old Jul 17, 2008 | 01:15 PM
Rippers's Avatar
Rippers
Monte Geek
Don't think Mike even has a set of spanners does he?
Old Jul 17, 2008 | 01:18 PM
Warren's Avatar
Warren
Jen does, she does all his work now. I'm told he even has a spot in the garden he sits at so he doesn't get in the way...................
Old Jul 17, 2008 | 01:20 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
could you not just cut/grind 5mm off the end of the diff case.
Old Jul 17, 2008 | 01:23 PM
Rippers's Avatar
Rippers
Monte Geek
Wish my wife would help, but I think our 2nd baby's bump might get in the way under the car another reason why this car needs to be finished sharpish as she'll be here around 23rd Sept
Old Jul 17, 2008 | 01:24 PM
Rippers's Avatar
Rippers
Monte Geek
I did think that but the mount is fixed up to its furthest position on the chassis
Old Jul 17, 2008 | 01:25 PM
Mike Rainbird
Caraholic
You can tell it's me by the bald patch .
Rippers's Avatar
Rippers
Monte Geek
At the end of the day triming that bolt won't be the end of the world, I just thought I was doing something wrong
Old Jul 17, 2008 | 01:26 PM
Mike Rainbird
Caraholic
I'll get you pesky kids
Old Jul 17, 2008 | 01:27 PM
Warren's Avatar
Warren
You can Mike but clearly you've missed your calling on the offside
what a place to take a nap
Rippers's Avatar
Rippers
Monte Geek
quailty pic
Old Jul 17, 2008 | 01:30 PM
Lloyd's Avatar
Lloyd
elongate the holes in the mounting bracket as well then ?
