ok who knows about megasquirt ecu's ?
just finding my feet
who was it on here who knows about it
wanna look at options of ecu's and been told to not overlook this !
Colossal Pervert
All there is to know about MS:
1) It works. As in successfully runs an engine, quite well when mapped properly.
2) Most of the bling features are very primitive- some work, most dont.
The End.
The End.
Colossal Pervert
You're not risking an engine. Sure, assembling your own ECU when all you've got is a 100 watt soldering iron sticking out of your arse isn't necessarily the best idea, but purchasing a ready-made ECU that has been soak-tested is no different than buying a.n.other aftermarket ECU.
Colossal Pervert
PWM idle and boost control are two things that spring to mind.. i'm sure they'll work, eventually. It's not a criticism of the ECU, it can control an engine very well, but I personally think the two old cunts who are responsible for it (by name, at least) should wake up a bit - redesign the core of it, make it easier for good people (like phil@extra) to make it work properly and spend less time arsing about with bullshit featuresets.
yeah thats a GOOD peice of advice there,,,,, lets IGNORE if it works and worry about what it looks like to others
have you seen other aftermarket ECU's,,,, they look cheep also tbh
ps: aint you always having a dig at my spelling dave ?
DixieTheKid
14-09-2015 09:04 PM
