what % on leakdown test, update rings are gone :(
can anyone give me a rough idea on what percentage im looking for on a cylinder leak down test please
bore size is .25th oversize and comp is 7.2-1
on cosworth
thanks
on cosworth
thanks
no readings yet, going to book the car in tomorrow at a local skyline place again, so will know this week, just need to know what sort of percentage im looking for when they give me the sheet
as it could be on the card for new rings again![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
im so not having much luck with this car, but im not giving up just yet
well im having it done to see if my rings are fukt or not, ive took the exhaust manifold to check exhaust ports to see if theres any damp patchs as last time the rings went the ports were full of oil, but its bone dry in there
i also need to take inlet off to see if theres any oil in there, as i heard this shows possible turbo
though the car started to smoke after i fitted the turbo, but its not turbo symptons
just had the test done
was tood there watching the gauge results are
1 - 30%
2 - 10%
3 - 30%
4 - 30%
so now i have to stri the engine and measure the bores to see if i can get away with a hone or not, if not then its a rebore and new pistons again
so end of the month the cars getting get it, and ill upgrade the cams,turbo, injectors and inlet aswell this time, and get some proper power out the car lol
1 - 30%
2 - 10%
3 - 30%
4 - 30%
1st to 200 without NOS
1 - 30%
2 - 10%
3 - 30%
4 - 30%
1 - 30%
2 - 10%
3 - 30%
4 - 30%
it could be anumber of things though, overfuelling etc
ill be the first to admit its never been mapped or set up, so its my error and im paying for my mistakes, even though im not running full boost to what it should of been doing
number of things that it could be, but i wont know until i take the engine apart and have a look, so end of the month the tax runs out so ill do it then, as there stil a load of things need doing, like braided hoses for fuel systm etc, uprated gearbox and diffs, brakes
its all going to get done when i can afford to get the bits and its not coming out until its all on and im happy with it
i will have a quick xr4x4
bores werent rusty, bar the very top lips but this wiped off with your finger
i ran it it on full mineral oil, i did 10 mins, oil change, 100 miles oil changes, then when it was 500 il change, then 1000 it was fully synthetic oil
all low boost max 10 psi
when they were doing the test, my breather system was constantly chucking out oil vapours through its filters, and this does it when im driving along aswell,as i can see the vapours coming out the bonnet
i carnt remember what the rings gap were, but i remember they were in tolerence when checked as that was the first thing to check
fuelling wasnt checked, i just went by instructions, but thats my own stupid fault and im paying for it
though i should of sent the chip back and had it re done for the ported head whch i never done
its definitly rings and it will be sorted again, but better this time
i will do everthing by the book, from running into to set up and mapped
nothing else i can do, the car doesnt get driven hard either, only quick blast now and then as i dont go out much and have other cars to use
ill sort it
ill sort it
Engine Machinist
make sure you get the bores checked for wear (all the way down) when you take it apart... rings going that quickly is quite often due to bore wash (as tony was thinking). maybe a fault with one of the sensors?
i'll quite happily check everything out for you if you can get it to me... it wouldn't matter who built the engine if the fuelling is the problem!
i know on when i first started the car up it bore washed, but got turned off straight away, this was becuase it had the wrong injectors in
so the damage was proberbly done then at the start
i can get the engine checked out up here, but thanks for the offer
it ran for 30 secs mate, i just needed to make sure it started, then the correct injectors were next day and it ran perfectly
i dont do diy on engines mate
everything else i do bar engines, as i dont trust myself,i do get the machine work done and then let someone else build them,
but this car is the only one ive had so much trouble with, it will be rite one day, ive come to far to give up on it
deathrider666
28-09-2015 06:12 PM
SMILER258
28-09-2015 09:04 AM
