Would you use 2nd hand Cossie Rods?
Hi,
A set of 2nd hand cossie rods has come up for sale at a not terrible price. The story on them is they were bought as a spare for racing but never used and they have stated came from a road use only engine. They claim that they have raced for years (8) on another set and have simply not needed them. Assuming everything the guy says is true and they have only had road use and you used new rod bolts would you use them ?
And while I'm at it, are valve registration marks in cossie mahle pistons common ? This guy also has a set of second hand pistons up for sale which 3 & 4 has some pretty nasty marks on them.
TIA -Andy
TIA -Andy
*** Sierra RS Custard ***
Ive never used anything but used rods in YB's TBH, along with most folk on here, but its better if you know the history, sellers lie a lot of course.
If the rods were on the pistons when they got damaged the rods could be out of true.
Measure the carefully before using them if you do buy them.
id get them checked, balanced etc with the engine and you'd be let know by your engineer if any problems occur with them, second hand should be fine if all of them are straight tho
as above most people on here seem to be happy with sued yb rods but consider the cost of refurbing them;
check for straightness £10
new little ends £50
big end hone x4 £60
new bolts £60
= £180. a new set of en24 rods is about £300 (got mine from OZ on ebay) and you can sell your old ones for £50+
new little ends £50
big end hone x4 £60
new bolts £60
Former Sponsor
if i had the choice of new rods from OZ on ebay or a set of used ford ones i would ckose,and have done loads of times,the ford ones,every time,no problem at all with used ones,and as for them bending,it takes one hell of a force to bend them.
pistons with valve marks,i bet 90% of the cosworts out there have pistons with valve marks!!
in all fairness i'v used lots of 2nd hand rods even the odd set of pistons. you can check the rods wich is straight forward but the pistons are another matter as we know they get a bit of slap after a few miles, unknown pistons even if they look fine can have a bit play not evident when you build up due to new rings and a rebore they seem fine only to rattle after a few miles not bad but anoying. they are not easy things to check as they are not truley round. ring lans wear and can have cracks in not easy to spot and can break out and fook the block and fook the whole thing up. it all depends how good they are mahle are the std ones used if your not going big power and want a cheap yb why not. i presume you are useing a pinto cranck as you asked the question about how much power they could handle. what block are you going to use do you have a yb block or are you going to use a 205
as regards pistons i also got a set of 0.5mm pistons off ebay for £50. there were 5 off them (1 new) as the original 4 all had valve/piston contact and the guy decided that the worst one was unuseable. anyway the new one was a good reference to the state of the used ones and although the used ones still had all the concentric fine grooves on the sides they were all out by about 2 thou across the skirts. there was also a noticable difference in the fit of a new pin in the used pistons compared to the new one. not sure how much these factors would impact on thier useability though - prob ok for most budget applications. for the record my genuine cosworth pistons had about 5k miles of hard use in a 400bhp spec engine and had no measurable wear and neither did the bores
new little ends £50
big end hone x4 £60
new bolts £60
new little ends £50
big end hone x4 £60
new bolts £60
argopetti - the rods apparently are made in oz by these people www.ppmrace.com
looks like £340 a set now (+ del). there are other vendors of yb rods on there though as well
Adam Graham
06-09-2015 06:04 AM
