fuel pressure gauges.
yh im going to order a 60mm defi Bf one.. just thinking what other gauge i will need aswell. Mike any other vital gauges i need? i got voltage, oil pressure,boost.
I would have gone for a stack AFR gauge ut they dont make them 60mm.
Testing the future
i've often seen those small ones in the fuel line and wondered what the point is. they will tell you the fuel pressure at idle, but won't tell you if it's being raised on boost when it's most critical and when your fuel pump may not have enough capacity
just finding my feet
but they look like a race car when you lift the bonnet pmsl
ive often wondered the point of oil presure gauges,,,,, as when its dropped the engines alread fucked aint it ?
oil temp is good,,, voltage,,,, erm not sure on that tbh cause that tells the battery not the power to the pump/ecu which would be more important im sure
boost is good though as it moves and AFR ( one that works ) is also good
Cake lover!
My gauge saved my engine atleast once as i noticed the pressure dropping. Turned out the oil return from the turbo was split.
Caraholic
how cool is that
On the Defi's you can set the alarm warning function as high as you want. You are confusing the standard oil light with a proper gauge, as by the time this comes on, your engine is most likely fucked. However, I have my warning set at 2 bar, so this should give me plenty of warning if it goes below this in normal driving. Obviously it is on at idle, but I know that isn't a problem.
ok a few reasons it may help.... but most times its just gonna get you paranoid
ps: yes i have a oil presure gauge in my car anyway
a alarm is a great idea,,,,, but whats the most comon reason for the oil presure to be low ?
you know what im getting at though, im not arguing,,,, just commenting about the general irony of the oil presure gauge as most times it just tells you bad news
