Fuelling problem help techies!!!
Boost Builder
Right its a scoobie but not asking there as never can get any tech answers there....
My95 classic scoobie (missis car) has been sat a week as she been away with work.
Come to start up and its lumpy etc. Wideband is either lean as fuck (18.1) or its all over the scale lean rich lean rich like mad. LC1 is controlling what ecu is seeing (inplace of standard lambda) and shows no fault on calibration, engine temp sensor is new, does it on lambda control and wot but no engine check light.
Any ideas???? ive put frsh fuel in too
Any idea where diagnostic plug is on scoobs?? i can then connect up lappy and see what sensors are showing ecu
i shouldnt think it would go into limp disconnecting lambda would just stay open loop and put light on. id say id plug our jap machine in and have a look but it was nicked out of my van on friday! have you checked the output to ecu with a multimeter yet to see if its switching properly?
Boost Builder
not done a free air calibration, not checked outputs either, will disconnect lambda in morn and then will try to find diag plug again and see what laptop comes up with
LC-1's can be very problematic.
Either throw a narrowband back in, or leave it unplugged and try it.
Although a description better than lumpy might help. Is it off cylinders ? At idle, or all the time ?
Will it drive ?
Have you checked the coils and plugs ? These can often be damaged when people are fitting plugs. Over time the coils can go brittle, and it doesnt take much to break them. People also lose the rubber insulating boots somehow, or damage them.
You wont be connecting a laptop up easily....unless you develop some software to do it lol.
But there are connectors under the dash that will flash any fault codes. Very easy to do, although if the CEL isnt on, then chances are things are ok.
Will it drive ?
Testing the future
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
