pectel mapping software
Old Jul 4, 2008 | 07:11 PM
Bart's Avatar
Bart
Default pectel mapping software
I have a L6 ecu modified by pectel to run 8 injectors and boostcontrol, now i'm searching for the software so i can map this ecu. Anyone of here who can help me out?
Old Jul 4, 2008 | 07:14 PM
J1mbo's Avatar
J1mbo
B1mbo
its just the same as normal webber ecu mappping i think
its when you start to use t2/t6/t62000 then you need
different software i think !
so to map it ou need ahmed/stu . .
i think thats all about right lol
Old Jul 4, 2008 | 07:17 PM
Bart's Avatar
Bart
Don't think the normal webber software will work because the pectel board has its own encryption so i think it needs it own software.
Old Jul 4, 2008 | 07:19 PM
J1mbo's Avatar
J1mbo
B1mbo
i think they both use hexidecimal dont they ? if not i stand corrected
Old Jul 4, 2008 | 08:09 PM
RickyLee53's Avatar
RickyLee53
I'm interested in this also.
Old Jul 4, 2008 | 08:21 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if it was that easy, we'd all be doing it
Old Jul 4, 2008 | 08:28 PM
Bart's Avatar
Bart
There is no engine tuner in Belgium who can map a pectel super 8 ecu so i'm trying to get the software so i can do it myself.
UK tuners don't do off the shelf chips for 500+bhp engines.
Old Jul 5, 2008 | 12:24 AM
stevieturbo's Avatar
stevieturbo
C**t
Often where there is no local tuner to work with an ecu....its much wiser to buy an ecu they can work with !!!! Or that software is available universally for anyone to work with.
Old Jul 5, 2008 | 05:37 AM
Or an ecu that doesn't NEED any software other than supplied and a std laptop!!
Old Jul 5, 2008 | 08:11 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
oh yes we do as long as we have your full full engine spec that is accurate we can post you a chip
I can also supply you the pectel software to map it but that would be costly and probably unnecessary.
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
