Newman solid lifters
Old Jul 1, 2008 | 09:04 PM
mk3stevie's Avatar
mk3stevie
Default Newman solid lifters
Hello people, anyone with newman cam/solid lifters fitted to RST? Have you had or know of lifters failing?
Old Jul 1, 2008 | 09:18 PM
Karl's Avatar
Karl
Norris Motorsport
We use newman cams in all our CVH engines, and have never had anything you would call a failure. HOwever we do get what I can only call "crazy paving" on the top face of the follower, where the rocker has been in contact with the adjusting screw in the follower. This however has not caused any issues, but it does seem to be a relatively common occurance.
Old Jul 1, 2008 | 09:27 PM
mk3stevie's Avatar
mk3stevie
Well you have heard of one now!!! lifter on number 3 exhaust valve has disintergrated. Ramains are seized in the bore and I suspect it has damaged the cam. Next issue is the metal fragments now floating around the engine
Old Jul 1, 2008 | 09:28 PM
Karl's Avatar
Karl
Norris Motorsport
What kind of failure has happened. i.e. describe it in detail
Old Jul 1, 2008 | 09:46 PM
mk3stevie's Avatar
mk3stevie
drove the car maybe 10 miles. Warmed it up as usual so it hadnt even been on boost. Stopped for fuel (V power of course) and when I wen to start the car it wouldnt start which was odd. Had to give give it a bit of throttle and crank it a while the second time then it started. Idled but didnt sound normal. Drove out of the garage and immediately could tell it had no power and was back firing alot. Pulled over and had it recovered back to my workshop. Did the basic checks then took the rocker cover off. Number 3 exhaust valve wasnt opening. Took the rocker arms off of cylinder 3 and the exhaust follower wouldnt come out of its bore. Unscrewed the top of the lifter and could see straight down onto the cam. The remains of the lifter are stuck in the bore but the base of it is completely gone and there are bits of it floating around the top end.
Old Jul 1, 2008 | 09:55 PM
Karl's Avatar
Karl
Norris Motorsport
Sounds to me like lack of lubrication. Normally this is a result of low oil pressure, so as soon as you can get the engine running check the oil pressure.
Also check the lubrication holes for the lobes in the head casting are'nt blocked, as this kind of failure is common in CVH heads that have sludge build up in these holes.
If all this checks out fine then the only other cause of this failure is incorrect tappet clearance on that lobe. If the tappet gap was too tight it would result in constant base circle contact and eventually cause follower damage like you describe. Like wise an excessive clearance would batter the follower face, but this is probably unlikely as you would have heard excessive clearance before the failure occured. Remember too tight a clearance causes as much damage as too large a tappett clearance!
Hope this helps.
Old Jul 1, 2008 | 10:01 PM
mk3stevie's Avatar
mk3stevie
Thanks for that Karl, I am gutted as only had car 4 weeks, and driven it 3 times, done 330 miles and 250 of that was bringing the car back form preston at a steady 50mph! Didnt sound particularly tappety, oil was clean and bang on the mark. I also know AJC and DAZ C fitted a brand new oil pump but I will check the pressure.
Kindest Regards
Steve.
Old Jul 2, 2008 | 07:44 AM
T28 RST's Avatar
T28 RST
Ok then
I had had a lifter fail on my S2, the bolt sheared off of the top of the lifter, AVA then replaced the full set of lifters.
I have a pic of it in Photobucket somewhere
Old Jul 2, 2008 | 05:54 PM
mk3stevie's Avatar
mk3stevie
Were they newman solid lifters?? Did you have to replace the cam also?? I am looking st other options, everyones opinion seems to be that newman are the best but I am not now convinced??
Old Jul 2, 2008 | 06:02 PM
TimC's Avatar
TimC
Is this Andy's old rs1600i turbo?
Is so thats unlucky and hope you get it fixed without too much dificulty
Old Jul 2, 2008 | 06:22 PM
mk3stevie's Avatar
mk3stevie
It sure is Tim, driven it 3 times and this happens. No fault of Andy or Daz, they have done a cracking job on this car, its just bad luck but I am absolutely gutted
Old Jul 2, 2008 | 06:43 PM
TimC's Avatar
TimC
Real shame. Its the car I always wanted Andy to bring to the cheshire meets when i attended but he'd just got his monte back from reyland at the time so its anyones guess which car he'd rather of played with.
Shorty said its a mental little car
Old Jul 2, 2008 | 06:45 PM
gus's Avatar
gus
sorry bit of a swerve on the topic
do you not rat ethe roller rockers anymore then karl?
Old Jul 2, 2008 | 07:07 PM
DazC's Avatar
DazC
I forgot about them!
Old Jul 2, 2008 | 07:12 PM
gus's Avatar
gus
they still in the back of my mind
just the bloke who i had lined to make them dont wanna play ball
then i heard ollie had a couple of issues
Old Jul 2, 2008 | 08:28 PM
Karl's Avatar
Karl
Norris Motorsport
Yes I do rate roller rockers, just not the alloy items that are floating around from donkeys years ago. We went through 3 sets and failed every set due to fatigue of the alloy.
We did consider making some steel roller rockers, but have gone a different route now, so won't be making any more up.
Old Jul 2, 2008 | 08:38 PM
gus's Avatar
gus
so you new option is better
as i did speak to you a while back and you had the tooling to make them
Old Jul 2, 2008 | 08:45 PM
DazC's Avatar
DazC
Karl,
Your better option at improving the CVH valve train. Is it expensive/worth fitting to an already assembled and running CVH?
Old Jul 2, 2008 | 09:30 PM
shifty's Avatar
shifty
My brothers RST had a newman cam lifter destroy itself when we investigated the problem we found the cam lobes had been machined out of line with the lifter. newman said they had a bad batch of cams and sent him new cam and lifters foc.
Old Jul 2, 2008 | 09:37 PM
mk3stevie's Avatar
mk3stevie
Thats interesting. I emailed Newman yesterday but have had no response.
Old Jul 5, 2008 | 03:21 PM
mk3stevie's Avatar
mk3stevie
Managed to remove the remains of the mangled lifter, Cut a new thread in the top and used a slide hammer
On inspecting the cam it appears that the cam lobe is not central to the lifter? Could this also be a manufacturing fault with the cam? I will try and get some more pictures up.
Old Jul 5, 2008 | 06:45 PM
DazC's Avatar
DazC
Fuck thats bad!
Old Jul 5, 2008 | 07:15 PM
TimC's Avatar
TimC
Jesus that aint healthy
Old Jul 5, 2008 | 07:32 PM
mk3stevie's Avatar
mk3stevie
Originally Posted by DazC
Fuck thats bad!
Told you it wasnt pretty! Glad I managed to get it out without damaging the head. Just got to get the rest of it out thats swimming round the engine.
Want to keep the same set-up but am unsure about fitting another newman now. Any suggestions?
Old Jul 5, 2008 | 07:36 PM
boothy's Avatar
boothy
thats a bastard that mate hope you get it sorted, cheers rob
Old Jul 5, 2008 | 07:53 PM
mk3stevie's Avatar
mk3stevie
Tell me bout it, gutted!
Old Jul 6, 2008 | 03:58 PM
legend289's Avatar
legend289
Quite often the cam isn`t central on the lifter, it helps even out the wear by rotating the lifter, there is usually a slight angle ground on the cam too, like half a degree.
Old Jul 6, 2008 | 09:02 PM
mk3stevie's Avatar
mk3stevie
It is noticibly so over the other seven though? Just doesnt look right to me.
Old Jul 6, 2008 | 09:33 PM
shifty's Avatar
shifty
Thats the same as my brothers. ring newman direct mate should get a replacement he did.
Old Jul 6, 2008 | 09:52 PM
mk3stevie's Avatar
mk3stevie
How long ago did he have the problem with his?
Old Jul 6, 2008 | 11:08 PM
T28 RST's Avatar
T28 RST
Ok then
Yes they were Newman Lifters
The cam was fine
Old Jul 7, 2008 | 07:51 PM
mk3stevie's Avatar
mk3stevie
My cam most definitely is not fine. Does any one produce a better solid lifter kit as I get the feeling these are not what they are cracked up to be.
Old Jul 7, 2008 | 08:08 PM
Ryan's Avatar
Ryan
bloody hell, glad you found what the cause was, but so sorry its something so major, and not a simple electrical fault
Old Jul 7, 2008 | 08:18 PM
mk3stevie's Avatar
mk3stevie
Yeah can you believe it did that on start up! Must have been wearing funny for some time and just chose that moment to let go completely so it wouldnt open the valve anymore.
Still, new cam, lifters and a good flush through and should be sweet I hope.
Old Jul 23, 2008 | 07:21 AM
AJC's Avatar
AJC
any joy with any news yet steve?
Old Jul 24, 2008 | 11:22 PM
mk3stevie's Avatar
mk3stevie
Not yet Andy, was hoping to have it done for ford fair but havent had time to do a thing with it.
Sapphire looks a good un mate, fancy a px!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
SMILER258
Sep 28, 2015 09:04 AM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
