Volumetric efficiency???
Old Jul 1, 2008 | 07:15 PM
TiB's Avatar
TiB
Default Volumetric efficiency???
What things can be done after an engine is built to improve VE?
i presume helping midrange would sacrifice top end and visa versa?
Old Jul 1, 2008 | 10:34 PM
markk's Avatar
markk
more boost improves the VE of an engine ! #
Old Jul 1, 2008 | 10:36 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Are we talking changing parts or mapping?
Old Jul 1, 2008 | 10:38 PM
Karl's Avatar
Karl
Norris Motorsport
Without any question the biggest difference to any engine is by fitting a larger turbo!
Old Jul 1, 2008 | 10:47 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Would VE increase if you kept the same sized turbo exhaust housing but changed the compressor housing to a larger item...
i.e. T3 0.48 -> T34 0.48?
Old Jul 1, 2008 | 10:50 PM
Karl's Avatar
Karl
Norris Motorsport
Not directly no, as you have not reduced exhaust back pressure. You would however get increased VE by raising the boost above that which the T3 can run.
Old Jul 2, 2008 | 08:24 AM
TiB's Avatar
TiB
Sorry... thats me not explaining things... i meant when the engine is built with turbo inlet etc on and it all runs,
For instance a large turbo can surge partly because of not enough VE etc so would adjusting the cam timing make the engine more efficiant at different rpms? ie giving it more midrange than top end.
And if the cam timing worked that way is there anything else that can work?
Just after seeing rods turbo post about the size of it.
I also remember euan saying ava did some testing on cam timing to give power till the 8000rpm but would that not sacrifice some midrange etc.
Lee
CrOwSoN15
18
Aug 22, 2015 10:24 PM
Stu @ M Developments
Technical essay Archives
31
Mar 1, 2011 06:35 PM
Oct 12, 2007 02:36 AM
Garage19
May 21, 2005 02:50 PM
sailorbob
Feb 25, 2005 05:40 PM
