standard cams Vs BD10 cams
30-06-2008 | 09:13 PM
as title,whats the pro,cons over these cams?is there any other option with regards to cams on a standard engine??
30-06-2008 | 09:27 PM
the van has BD10s so i guess they are good cams no idea about the spec of the bottom end
30-06-2008 | 09:34 PM
don't know much but i would rather have standards than the bd10's...
30-06-2008 | 09:35 PM
slightly more top end power, but less torque generally
30-06-2008 | 09:46 PM
mine had more lag when had the bd10s fitted plus you couldnt tell any difference
30-06-2008 | 09:55 PM
mates got 10's on his 34 powered saff and its very torquey in the mid
30-06-2008 | 09:58 PM
my saff on a t34, with std cams was over 400lb/ft
30-06-2008 | 09:59 PM
thats 50/50 at the mo,wondering if it will be worth putting some bd10s in mine and going up too a .63 housing
30-06-2008 | 10:01 PM
no real need, std cams are very good,
Is there any better cam suggestion to give a bit more responsiveness?
Ive heard standard cams are the best for this though, is this true?
30-06-2008 | 10:03 PM
hmm jtechsaff if that the case not really worth me just putting on a .63 housing might as well leave her alone!i did her of a different fast road cam for a cossie asked on here but got no joy!think it is a bdr10?
30-06-2008 | 10:04 PM
Quote:
Originally Posted by
JTECHSAFF
Posted before I had time
So it is true then.
I juist find my car a little too 'laggy' (well boost threshold), just wondered if any particular cam set ups would improve the way it came on boost>?
i am sure you get a bd8r which is better than std and a 10
30-06-2008 | 10:10 PM
group n spec?? for better response
30-06-2008 | 10:20 PM
i am the other end of the spectrum as i am running a T3, would BD10's give me more top end power, with sacriface to a little mid range torque?
30-06-2008 | 10:24 PM
Bd14 inlet. Some people get away with no valve cut outs in their pistons, other like me have big enough for no worries what so ever.
cos elle
25-09-2015 09:52 AM
IainRS1700T
25-09-2015 06:44 AM
focuspower
19-09-2015 08:27 PM
CrOwSoN15
14-09-2015 11:33 AM
grishenko45
09-09-2015 12:58 PM
