afr gauge recomendation and defi egt gauge problem
hi im looking to fit a afr gauge to the cos can anyone recomend one thats accurate.
and my defi exhaust temp gauge seems to be faulty it will suddenly jump from 600 to 900 instantly then drop to 500 instantly im thinking temps cant raise and fall that quick so must be a fault. is the temp sensor that fits in exhaust available separately ?
Colossal Pervert
The only truly accurate ones are the calibration quality ones, but they cost thousands... Out of all the cheapie ones, there isn't much between them, so just pick whichever one you like the look of. They all 'work'.
Caraholic
Mine lasted several years of constant abuse including ALS before it started to do as you describe. Firstly I would check the connector plug, as despite supposedly being a proper water-proof connection, the pins do get furred up. I managed to get another year out of mine by cleaning these before it needed replacing. And yes the sensor can be replaced .
thanks mike il give it a clean tonight. should i take the sensor out of the exhaust and wire brush the probe aswell ?
Any k type thermocouple will be pretty accurate and don't cost that much. I always use this over any in car type gauge.
Colossal Pervert
will be telling you on boost your car is optium if its around 14:1 when it should be closer to 11's
dont most wideband afr gauges use the same bosch sensor including lots of the more proffesional ones? in which case how can the cheaper ones be less accurate? Is it how they interpret the sensor?
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
