CNC machinists, can anyone do this for me (pics inside)
i think you are looking at quite a bit to machine them, from the pics there doesnt seem to be anything obvious to clock them from and without a fixture or a drawing its gonna mean quite a bit of time on a CMM.
Through work i use a company called Arrowsmith in Coventry for quite alot of our subcon machining, might be worth a call.
02476 368126 ask for Ben Kitson
cnc people
hi martin, the man you need to speak to is steve bones. owner of fabrication technic in buckingham. if he,s good enough to build the foggy petronas racing bike frames, i,m sure this would be piss easy! also a dab hand at any custom rads, tanks,coolers, exhausts or the like!! his no is 07976732605, and tell paul the plasterer gave ya his no!!!
James Engineering would be a good compay to use, if you supply them with the machined one aswell they will be able to machine it the same.
Their Address is
James Engineering Ltd
Prenton Way, North Cheshire Trading Estate, Prentonead, Prenton, Merseyside CH43 3DU
Tel: 0151 609 1000
http://www.jameseng.com/engineering/...gineering.html
Their Address is
Tel: 0151 609 1000
You could try ttvracing.com Martooon. They are always busy but are very good and well priced. They are based just up the road from Ipswich, but do a lot of work by mail order.
Ross.
Ross.
if you get stuck , let me know as i have afew connections with CNC machines available, resonably priced too normally as i write their programs is it just 5 or a possibility of more in the future?
155lee
06-09-2016 11:10 AM
timsrs
22
24-09-2015 08:14 PM
