Life Racing ECU
Old 26-06-2008, 10:07 PM
  #41
DazC
DazC's Avatar
Harvey,
My car is my toy and the list of toys I require is a variable. I want to be able to add and subtract toys from it as and when I fancy having a play around.
So with that in mind, I think I am better aiming for a full unit.
My list of sensors and features that I planned to run initially is as follows...
Inputs,
5 bar map sensor
crank position using 36-1 tooth patern
cam position using 1 single tooth (this was originally specced for the T6 I had)
Throttle position
Inlet air temperature sensor
Coolant temperature sensor
Fuel temperature
Oil temperature
Exhaust gas temperature
Oil pressure
Fuel pressure
Ouputs,
Idle speed control valve
4 x high impedance injectors
either a coil pack or 4 individual coils
Air to air injectors
Fuel pump
Cooling fans
I would like to play around with full throttle gear change, launch control and ALS. 2 of the features if not all 3 would be best using a clutch switch.
I would also like to possibly play around with the drive by wire and use a throttle body with such capabilities and ditch the idle valve.
I am also considering individual throttle bodies in the future and playing with closed loop boost and maybe (without using ALS etc) closed loop fueling.
I assume these units have adaptive mixture compensation too.
I think thats all I was thinking about. Maybe I'm asking too much but I want something that I can adapt easily.
Old 26-06-2008, 10:08 PM
  #42
DazC
DazC's Avatar
Also forgot to add that this ECU may end up on other cars in the future also.
Old 26-06-2008, 10:10 PM
  #43
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Originally Posted by totalbhp
Hi martin i would have to say yes to that have spent quite a bit of time with the f88 have not found anything it cant do can make a call and find out for def tomorrow if you like
I will give them a shout to save your time
Old 26-06-2008, 10:16 PM
  #44
totalbhp
totalbhp's Avatar
no prob leave it to you
Old 26-06-2008, 10:18 PM
  #45
Martin-Hadland
Careful Harvey you are now up to 18 posts
Old 26-06-2008, 10:19 PM
  #46
totalbhp
totalbhp's Avatar
Originally Posted by DazC
Harvey,
Inputs,
5 bar map sensor
Throttle position
Fuel temperature
Oil temperature
Oil pressure
Fuel pressure
Ouputs,
Fuel pump
Cooling fans
you are not looking at any thing to complecated there both ecus will do all your list and much more
Old 26-06-2008, 10:21 PM
  #47
totalbhp
totalbhp's Avatar
[QUOTE=martin-reyland;3386789]Careful Harvey you are now up to 18 posts [/QUOTE
Trying to get to 20 this year
Old 26-06-2008, 10:26 PM
  #48
Chip
*** Sierra RS Custard ***
Chip's Avatar
You just did, lol
  #49
DazC
DazC's Avatar
Already made 20!! You need another target.
So with this reasoning, I need to ring both Life and Pectel and get them to either give me as much info over the phone or email me the information and prices so I can make an accurate descision....
No one has anything bad to say about either ECU so I'm down to basics of speaking to each supplier and see which one sells it best to me.
Thanks for the help.
Old 26-06-2008, 10:36 PM
  #50
markk
markk's Avatar
I need my new ecu to do as a minimum, drive by wire - in full range, EGR control, Launch strategies, dual map, anti lag, as well as the std ign/fuel options. most fall down at the drive by wire.
If im thinking what martin is thinkin then a diff control option againts wheel speed is in that list - if you can find this out Harvey then we may be having a chat
Daz the DTA needs the control box to make adjustments live, although the S series software is alot better than the old DOS based crap.
Old 26-06-2008, 10:40 PM
  #51
Ryan
Ryan's Avatar
list price for an F88 is 2200 + TWAT as far as aware.
Old 26-06-2008, 10:46 PM
  #52
DazC
DazC's Avatar
Mark, I forgot about EGR and dual map. Dual map could be handy if you have 2 cars and can swap the ECU from car to car!
I did fear that you still needed the knobs box for the DTA.
2200 plus VAT makes it dearer than the SQ6! Which is 2000 and something plus VAT!
Old 26-06-2008, 10:48 PM
  #53
markk
markk's Avatar
it also makes it dearer than motec 400 by a couple of quid.
Old 26-06-2008, 10:53 PM
  #54
DazC
DazC's Avatar
Right, I'll try and find time to phone them tomorrow and see if I can get some ideas and info together.
I'll let you know how I get on.
Old 27-06-2008, 04:15 AM
  #55
gus
gus's Avatar
while your on the phone then, i would definatly phone tommy field at FMS, he will be able to tell you all you need to know
the spec you listed above is very similar to what im using and f88 was chosen for my car
Old 27-06-2008, 07:28 AM
  #56
Rick
Rick's Avatar
Daz, MS2 Extra does all that and more lol
Old 27-06-2008, 07:54 AM
  #57
GARETH T
GARETH T's Avatar
my advice is to play about with the software, and see which one you get on better with! both ecus are more than capable
Old 27-06-2008, 08:33 AM
  #58
pa_sjo
Colossal Pervert
pa_sjo's Avatar
You can't compare MS to one of these.. features do not maketh an ecu!
Old 28-06-2008, 11:39 AM
  #59
DazC
DazC's Avatar
I didn't get chance to ring anyone yesterday unfortunately. Too busy, only leaving the workshop at 2.40am this morning.
I don't like MS Rick. Just the way it works just puts me off completely.
DixieTheKid
11
06-06-2020 11:20 AM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: Life Racing ECU
