Looking for Inspiration... Fast Ford readers help required.
Old 06-08-2008 | 06:21 AM
  #81
TimC's Avatar
TimC
Due to my new addition of a post about oil cooling, How about an article on lubrication systems, ideal operating temperatures of the oils inside an engine and methods of controlling temp, and choosing the correct grade oil for an engine.
Old 20-09-2008 | 01:48 AM
  #82
Stu @ M Developments's Avatar
PassionFords Creator
Thanks, good plan.
Old 20-09-2008 | 01:55 AM
  #83
RWD Pete's Avatar
RWD Pete
Why is it only fords manage to create enough heat to bend waste gate arms?
more boost than other more efficient engines? on same turbo
Old 20-09-2008 | 07:25 AM
  #84
cossie daz's Avatar
cossie daz
head gaskets! what gaskets should use for power at 280bhp, 330bhp,380bhp,420bhp and above aswell as any other mods like standard head bolts, ARP stud and nut kit and long studding! what actually works and needed,
thanks
Old 20-09-2008 | 08:19 AM
  #85
Mr Whippy's Avatar
Mr Whippy
Oderint dum metuant
Stroking and De-stroking, rod angles and why they are important...
Old 23-09-2008 | 03:36 PM
  #86
tore_tj's Avatar
tore_tj
Cossie Paranoia
I would like to read a guide to building say a 500bhp yb on a budget. What can you use from your original engine, and what SHOULD you change and have done.
What turbo is recomended for different specs, and why.
If you've already covered those then apologies
Old 24-09-2008 | 08:00 AM
  #87
Barry_GTi's Avatar
Barry_GTi
How TUV certification process for Engine Dyno's work???
Old 24-09-2008 | 11:33 AM
  #88
AustenW's Avatar
AustenW
Some suggestions could be:
Inlet primary length and how it affects an engine? both nasp and force fed
Determining throttle body size for both nasp and force fed, single and multi
Squish, how does it affect an engines ignition?
Also look at piston design and the variables surrounding its intended purpose
Destroking an engine, rod ratio's etc.
Old 24-09-2008 | 12:35 PM
  #89
davidreader5's Avatar
davidreader5
Originally Posted by JTECHSAFF
id be really interested to see what you can do to diesel engines aswell, mapping ,tuning etc, and what technology they use now, and how its evolved in the last ten years
Also how to size the correct injectors & fuel pump for your modified engine with safe duty cycle
most information available is rule of thumb,
Regards Dave R.
Old 29-11-2008 | 11:23 AM
  #90
Originally Posted by fraser9764
i know from reading the above suggestions i would like to read up on sparkplugs,and breathers
Done.
I am amazed nobody has asked for an article on AFR i must admit as it was on my shortlist as i thought folk wou8old like it. Doh!
Old 29-11-2008 | 11:28 AM
  #91
dojj's Avatar
dojj
Resident Wrestling Legend
too many peole already know what arf should be "cause i've got one of them gaues innit" stu
unless you have already covered it, there was a point about not mixing different antifreezes that i didn't seem to find in the last article, something to calfiry that as a ps might be worthwhile just as a little warning
it might also be worth while putting up a list of all the things covered in the artles to date and which issue numbers they would be in as a seperate page
Old 29-11-2008 | 11:30 AM
  #92
dojj's Avatar
dojj
one mroe thing, unless i've missed it, have you done one where you can explain what parts are needed to upgrade from one ecu to the next as far as cossies go?
i'm sure i've read a few articles on what you need to upgrade from small turbo to big turbo on the escos and a few about how to run cossie management on an rsturbo
Old 29-11-2008 | 11:32 AM
  #93
dojj's Avatar
dojj
one more thing, is it worth doing an article on parasitic losses and what can be done to lessen them in terms of those who want outright power from their engines?
electric water pumps, smaller alternators, the whole myth of the "under drive pulley" and how it relates to "giving you free power" etc?
Old 29-11-2008 | 06:46 PM
  #94
Dannyf1380's Avatar
Dannyf1380
Originally Posted by Stu @ M Developments
Done.
I would love to see an article on AFR, I question I have regarding AFR is what should it be at idle on a 2wd saff?
Old 29-11-2008 | 07:34 PM
  #95
jammerrs's Avatar
jammerrs
suspention setups for different uses???
carbrettors vs injection
Old 29-11-2008 | 07:42 PM
  #96
porksword69's Avatar
porksword69
Originally Posted by joffy
urban myths like
wastegate chatter that isnt the wastegate chattering??
That gets on my tits.
How about the gains from a good set of tyres?
Simple I know, but when I first got into motorsport I really didnt realise the gains to be had, and most people dont.
You could do on different tyres for different budgets.
Old 29-11-2008 | 07:46 PM
  #97
escort700bhp's Avatar
escort700bhp
couldnt agree more,theres more gains in tyre choice than most single mods!
Old 29-11-2008 | 07:49 PM
  #98
porksword69
Exactly. Taken a while but I'm slowly turning into a Jedi master of cutting extra grooves. How many how wide where so & so on.
Applying what I've learned on the rally stages to the road has made some big improvments.
Old 29-11-2008 | 08:32 PM
  #99
dave_y's Avatar
dave_y
throttle bodies would be an interesting topic i think.
Old 29-11-2008 | 09:10 PM
  #100
dojj's Avatar
dojj
engine related i think stu's asking for rather than everyting else
Old 16-01-2009 | 11:24 AM
  #101
Thanks for your input folks, some of which i have actually now written. BTTT
Old 16-01-2009 | 11:31 AM
  #102
Benni's Avatar
Benni
Ban[B][/B]ned
Have you done one on Compression Ratio? I've heard high compression on a YB is very bad. Yet the likes of MAD use it. Have you done one on what size turbo is good for what power? I see people laughing on here when say X turbo is mentioned at Y power and it's not possible.
Benni.
Old 16-01-2009 | 11:50 AM
  #103
It's Czech Mate's Avatar
It's Czech Mate
How about a topic on manifolds... the different types and benefits of different inlet manifolds both turbo ( ie swedish, 2wd with spacer etc ) an n/a ( throttleboddies/ carb etc ) and the principles involved.
Then you could look at exhaust manifolds and the effects of bore size, primary lengths, 4-1 , 4-2-1 and link it into a little topic on exhausts?
Old 24-04-2009 | 12:27 PM
  #104
Thanks Guys, Ive added a lot of this to my shortlist where I feel I have anything useful to offer. Back to the top for more input please.
Old 24-04-2009 | 12:39 PM
  #105
pani_k's Avatar
pani_k
PassionFORD Member
Maybe an article about how to strengthen/improve your bottom end? Talking about the block itself, crankshaft, rods, pistons, different types and stuff, different techniques? For example you don't see many people changing a crankshaft to get more power generally or increasing the bore of their engine until necessary. Also stroker kits?
Old 24-04-2009 | 12:40 PM
  #106
alanfordtw-15's Avatar
alanfordtw-15
everything seems to be mentioned, so just want to say great articles and keep it up. i much prefer reading about something i didnt know and learning,rather than how to fit an air filter
before i had a car i learned absolutly everthing i knew about them from mags
Old 24-04-2009 | 12:53 PM
  #107
OldDan's Avatar
OldDan
N/A Tuning - how the size of trumpet/body affects spread of torque power etc!
Old 24-04-2009 | 12:56 PM
  #108
Paddy's Avatar
Paddy
Legend
I don't know if it's been mentioned before but how about an article on how the modern Common Rail Diesel engines work. Or even something showing the difference between the old Endura and the newer TDCis?
Then something on tuning them.
And an article on why the Dual Mass fly wheels on the TDCIs are shite.
Old 24-04-2009 | 01:36 PM
  #109
natehall's Avatar
natehall
A big one i would love to read is the one about top 10 most common mistakes
It doesnt have to be in a "You done wrong, Your a muppet" Fashion (albeit funny)
It could be as mistakes to avoid to get the most out of a mapping session!
Old 24-04-2009 | 01:44 PM
  #110
PAUL S's Avatar
PAUL S
Dry sump systems, there best applications and installation/set up advice, preferably for YB engines
Old 16-05-2009 | 09:52 AM
  #111
Thanks Guys, ive written some of these now. BTTT for more input from the readers.
Old 16-05-2009 | 10:44 AM
  #112
Eagle's Avatar
Eagle
Super Moderator
suspension geometry and how lowering you car causes other issues and how they can be resolved...
Old 16-05-2009 | 12:44 PM
  #113
cjwood555's Avatar
cjwood555
Hi Stu,
AustenW's suggestions sound interesting although e.g. inlet design + tb sizing could probably be incorporated into one article...
Did your series on engine management talk about closed loop lambda control?
Have you talked about boost control strategies e.g. large turbo, restricting boost to give a flat torque curve in a high revving engine?
Perhaps a topic on launch control and traction control would be interesting?
Chris
Old 16-05-2009 | 02:05 PM
  #114
tarmac terriost's Avatar
tarmac terriost
section on what oils should be used in which engines standard and modded cvh, zetec, yb, pinto, ohv,dohc v6's etc and why it is important to use the right oil for the engine and not just putting any oil in
about engine flushing pro's and con's personally i think its a big no no
a section on how important it is to keep the car serviced
maybe a section on transmissions 2wd 4x4 fwd fords for eg how much power can the transmission, take which oils to be used in them which uprated boxes diffs lsd atb etc
clutches,hydraulic conversions cable driven fords
which are the best mods for the money gains in power etc
which are the best air filters, exhausts, etc on yb's zetec, cvh etc
which parts get the best results on these car for eg mongoose, milltek which ones would you reconmend
section on suspension, springs,shocks,coil overs strut braces camber adjustment kits
wheels sizes etc
Old 16-05-2009 | 02:47 PM
  #115
opposite lock's Avatar
opposite lock
GT30,s using internal wastegates vs using a T3 /T34/T4 advantages and disadvantages if any ?
Old 30-05-2009 | 11:58 AM
  #116
MarkN's Avatar
MarkN
I'd be very interested to read something about small turbo cossie tuning. I know its problematic - but am not exactly sure why. I know ther are ways around it - swapping to weber management etc. But can you get around the problem by ditching the EEC-IV and getting aftermarket management?
I don't think I've ever seen all the options written down in one place for the pros and cons of each.
Didn't you have something under development for this as well that retained EEC-IV? I'd be dead interested in this if you decide to market the upgrade...
Us small turbo owners never seem to get much written about our cars lol :-(
Billy_RS
15
05-09-2015 12:04 PM
TommysKeeper
13
14-08-2015 08:22 PM
Quick Reply: Looking for Inspiration... Fast Ford readers help required.
