HELP! Car is misfiring on boost..Stu, Gary, Karl please read
Yup, did it earlier this week too
First was on Wednesday morning, quite damp conditions and was fine night before (Norfolk meeting) when the car gets a good run and a clean out. As soon as it approached 1 bar (14.5psi) it misfired massively and had to let off, up to that point and after lifting off drove absolutely fine, it started perfectly, no stuttering, just while on boost
4 hours later I drove the car - no problems on boost and was fine upto the normal 1.7 bar
I took it out tonight (again very damp conditions as has been all day) misfired in exactly the same way
Now I bought a new Distributor cap and rotar arm on Thursday (haven't fitted them yet)
Is there anything else I could look at or change etc etc
This is really worrying me
Legend
sorry mate , thought you were saying that you thought the misfire was due to moisture getting in the dizzy? I jumped to conclusions.... I imagine it probably is though if ytou;ve noticed that pattern?
I just been trying to sort out my mates golf gti [fooking cars] which was suffering from the same problem, misfiring cos of moisture round the rotar arm
it was also cutting out at random times, but flashpoint reckons thats the alarm
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
I'm pretty sure it could be moisture in the cap, but haven't had time today to look at the car
A job for the early morning - Great, means I don't get any lie in
They haven't been changed for about 1 year, so best to change them as they are due to wear out being on a highly tuned car in any case
Sure Smit suffered from the same recently which made me buy the replacements in any case
Well, dist cap and rotor arm are looking as new as they were when taken out of the box, no damp in there at all, not a sausage, nothing LOL
Also removed all plugs and leads and checked condition - A1 ok!
BUT...
It still misfired on start up, only a little about 3,500 revs to 4,500
Took it out and no misfire...
What's going on people, I really need some help here
BUT...
Mark...
Standard coil only 1 year ago
Ford Bosch distributor cap and rotor arm only less than 1 year old
NGK9's for spark plugs - don't know gap as set when Gary mapped the car less than 1 year old
Leads are Magnecor 10mm (thick Red ones, sure 10mm) again only about 4 months old
Christian, I would go for the BCR8ES's but don't fancy using them due to the lovely stories we've all heard about them
It only does it in damp conditions (this last week has been VERY damp in the air) but only 3 times, hasn't done it EVERY morning and I fire up the car at 7.30am every morning to get to work
trial and error might help, swap some parts over from christians car to find out!
It will just be damp, happens to cvh's
i have taken the dizzy cap rotor arm plug leads and king leads and cooked them in the oven at 60 degrees before for 5 mins to dry them out.
Worked perfect.
RW
Worked perfect.
RW
Steven, the cap etc are dry as a bone mate, no damp what-so-ever on them, this was at 7am this morning too and was VERY damp in the air
Legend
Originally Posted by Steven_RW
i have taken the dizzy cap rotor arm plug leads and king leads and cooked them in the oven at 60 degrees before for 5 mins Worked perfect.
yawiejon
15
09-08-2015 06:36 PM
CabrioTurbo
01-08-2015 11:04 AM
