my car still wont spark
SAFCDIXON
i was wondering is there anybody in durham or sunderland with an rs turbo s2 who knows alot about these and the problums they have. iv bought a whole new ignition system except the ht leads and still no spark anybody got any ideas.im realy coming close to breaking the car any realy dont want to but its totally doing my head in HELP!
SAFCDIXON
yeah iv been messing round with th same wire gos right up into the ignition never noticed if it was melted though iv also put a new ecu onit new dizzy (Ł150 wot a rip) new plugs new coil new new dizzy cap and arm i will check that wire again cheers i no its gunna be something real simple but its had me baffled for 6 months nearly
SAFCDIXON
yeah this is also sumit ive been lookin into but it al seems to be fine if any1 has a pic ov there fusebox and relays it would be a big help! cheers
SAFCDIXON
i basicly just checked to make sure they r in the right place and then checked they wernt burnt on the prongs and i have more then one of most relays so i swaped them about i still nothing i havent got a clue how to check them properley is there a right way?
u need a 9 volt battery (the square looking ones)and a voltmeter,but the volt meter to check continuaty (sp)then but the battery across terminals 85 and 86 relay will click then get someone to put the voltmeter across terms 30 and 87 if all is good u should get continuaty!
SAFCDIXON
seeing if the realays are in the right place isnt going to tell you if they work..you need to do as above.. ahve you checked that the spare relays your using are not faulty?
SAFCDIXON
no but if there not in the right place then theyl never work but i didnt know how to check them before but do now
SAFCDIXON
yeah i bought one a few weeks ago to check the coil has power which it doesnt but yeah i have one. the shit thing about this is that it did start first time everytime since i put the engine in then i pop a driveshaft and fook all is there when its time to start again
Shizzle My Nizzle
had this on my rst, took days to find it, everything tied up. even the break out box readings.
fault was a short circuit from the coil to the ecu on the spark recgonition sensor wire.
there should be a small green wire coming from the coil, runs round the front past the lights, rad and back up to the fuse box.
if u can check this wire is not broken/shorting. it could be ur problem
SAFCDIXON
had this on mine, took days to find it, everything tied up. even the break out box readings.
SAFCDIXON
lol this is the second one but u may be right! but it acnt be much wrong when everything else is working on the car thats why im tryin to get this one workin and it a lot ov cutting and soldering when its in a cabby
SAFCDIXON
do ya think so i hope! wot ya think do cut it and put one long piece of wire in ? ill hold my hands up if thats wot its been wots happens if its got lots ov joins ? just thinkin tho m8 the black ones the power and the coil had no output will the fuked wire make it resist
check the wiring from the dizzy plug, just disconnect everything and un tape all the dizzy wiring to make sure there isnt a broken wire, you have to go through alot fo the loom and keep doing continuity tests to make sure
thats the only thing i can think is its going to be a broken wire somewhere wither dizzy side or coil side
SAFCDIXON
SAFCDIXON
na mine dnt thats why theres possibley a problum mine now run along the back ov the engine bay im goin out 2 give it a go now cheers for all ya help lads thnks
SAFCDIXON
cozzy jeff
14-08-2015 05:46 PM
Zoggon
10-08-2015 10:39 AM
