Bosch wideband linearisation curve, anyone have the info?
Colossal Pervert
That'd depend on the controller... The sensors themselves don't output a voltage as such.. if you've got one hooked directly up to a T6 or whatever then Pectel should detail the linearisation curve.
Colossal Pervert
Ah right. Well that linearisation curve above looks like when you add in your own WB into one of the ADC's.. I've not had a T6 personally, but i'm guessing there is a different configuration page for the NTK one?
sorry you are right if you are using a wideband controller, but there is no need of this on the t6, as a wideband can be conneted straight to the T6
Colossal Pervert
Correction, an NTK sensor can be connected straight to the T6, not an LSU4. As I said, you have to do it via a controller and through a spare analogue input configured as a wideband lambda.
Colossal Pervert
Yes.. I'm not 100% sure if Pectel now include a hardware cal for the LSU4, I did hear something but I don't know the details.. As you say, they want you to buy the expensive NTK sensor. I think they're promoting LSU4 usage (with a seperate controller) for T2/E2, but not for the higher-end stuff (but you can, as you can with the T2).
http://wbo2.com/lsu/lsuworks.htm
That pretty much says you need a controller with a 6 066 right??
There is no way can connect direct to analogue input as need to control current to the sensor.
Testing the future
Use an Innovate controller into an analogue input, that will be the most accurate as it it wont rely on sensor calibration resistors and will tell u if the sensor goes bad.
