st170 problem
Old Jun 15, 2008 | 03:08 PM
RichieST's Avatar
RichieST
Default st170 problem
hi everyone
Bought myself an st170 a couple of days ago. Its just started making a funny noise, from inside the car i can only describe it as an air pumping noise, something sort of turning over and over maybe? I've tracked it down and it sounds like its coming from a silver box mounted behind the inlet manifold, there's what appears to be a cable and a wiring plug going to it. The car still drives fine. Anyone have any ideas to what it could be?
Thanks
Rich
Old Jun 15, 2008 | 03:51 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
That particular box is the variable length runner control - pulls the inlet manifold runners open a bit further at 6000rpm IIRC...
Check the cable going into it hasn't come off the inlet manifold...
No engine management lights or anything?
Old Jun 15, 2008 | 03:53 PM
Oranoco's Avatar
Oranoco
My mates did this. Just sounded like something whiring all the time. No EMS light on his. We disconnected the wiring plug to it which silenced it but brough the EMS light up until he got it booked into Ford. Repair isn't an option they replace the unit.
Old Jun 15, 2008 | 04:13 PM
RichieST's Avatar
RichieST
thanks for the help guys. I've had a look at the other end of the cable on the manifold side, and the cable is there, it has a black piece of plastic on the end, that presumeabley connects onto the wheel bit? The end of the cable is just flapping in the breeze, and it isn't broken. So i presume there is nothing wrong with the box, just the manifold side? No warning lights have come on.
Rich
Old Jun 15, 2008 | 04:14 PM
Oranoco's Avatar
Oranoco
I know a man breaking an ST170 if interested
Old Jun 15, 2008 | 04:19 PM
RichieST's Avatar
RichieST
well i've only had the car since friday, it should be covered under the warranty, if not i'll just get it into fords to have it looked at. If its just a simple task of hooking the cable back on then i will do it myself, but I cant see any way that it will go back on, its pretty tight for space down there!
Thanks anyway
Old Jun 15, 2008 | 04:44 PM
RichieST's Avatar
RichieST
just been out to have another look after researching it a bit, and it appears that the plastic lug that the cable connects on to on the wheel bit has snapped off!
That bit right at the top. Looks like quite an easy fix, but gonna give the garage a ring in the morning.
Rich
Old Jun 15, 2008 | 05:11 PM
Oranoco's Avatar
Oranoco
Hope it gets sorted mate
Old Jun 16, 2008 | 10:51 AM
RichieST's Avatar
RichieST
well i've replaced this cam bit, went to ford and they had one on the shelf, so must be a pretty common part. Its still making the noise tho, but only a few times on startup and then it stops. Looked about on a few focus forums and it appears the control box thing is fooked too. So that will be a warranty job
Old Jun 16, 2008 | 10:53 AM
jonesy_23's Avatar
jonesy_23
it may be your air intake system, does it make a loud knocking noise aswell? I had one before my rs & it broke 2wks after i brought it.cost about £300 to fix by ford
Old Jun 16, 2008 | 11:33 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
do you have the cat and front pipe?
Old Jun 16, 2008 | 11:46 AM
tsutton's Avatar
tsutton
The IMRC box can be "broken" when the plastic cam has snapped off.
As you say it's still under warranty, get it fixed.
It happened to me and was fixed, sadly not under warranty!
Old Jun 16, 2008 | 01:11 PM
RichieST's Avatar
RichieST
yeah the noise is deffo coming from the IMRC box, perhaps it has been damaged by constantly cycling back and forth when the cam was broken.
Waiting for a call back from the warranty people, so hopefully it should get sorted
Old Aug 29, 2010 | 01:04 PM
ST83's Avatar
ST83
Hi all, I purchased a focus ST170 about 6 months ago & having a few problems, I have a scratching sound when I switch off the engine ( around the oil pressure gauge area )
Engine sounds tappy/ticking
Vibrating accelerator pedal above 80 mph
Some loud knocking noise, not sure where it's coming from but sounds really rough on idle. The noise goes when I apply the clutch, have fitted a new clutch & slave valve cyli nder. Dual mass flywheel was slightly worn but ok. Have been told this sounds normall for the st170 & it's the 5th gear idle in the gearbox but I am not convinced.
I would be grateful for any help on these problems or advice
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
Tank Mike
Sep 10, 2015 07:56 AM
