Turkish block strikes again on YUM this time
Old 19-06-2008 | 04:56 PM
  #321
Chip's Avatar
Chip
*** Sierra RS Custard ***
Originally Posted by JonnyBravo
That just answered my next question regarding my own engine
Can you use solids on normal hydraulic cams ?
you CAN use solids on hydraulic cams but they will wear quicker than on a solid profile.
The solid profile has a much gentler ramp at the beginning of it generally, to allow it to take up the clearance (typically thats about 10-15 thou depending on the engine) and the absense of this will cause:
more noise from the valve train
more wear to the cam
more wear to the lifters
Old 19-06-2008 | 04:59 PM
  #322
JonnyBravo's Avatar
JonnyBravo
I'll just stick to a new set of hydraulics then, I'm not wanting to have any cams made although I have no idea how well the xe cams will work with my turbo
Old 19-06-2008 | 05:04 PM
  #323
Chip's Avatar
Chip
XE hydraulic cams on solids is what im using intially, why not wait and see how mine wear first, lol
Anthony was on the same with no problems I beleve, but check with steve.
There is extra wear, but its not significant enough to worry about so much it puts you off using a particualar grind IMHO
Old 19-06-2008 | 05:17 PM
  #324
JonnyBravo's Avatar
JonnyBravo
I'll see how you get on Chip, I've got a while yet before I start worrying about that
Old 19-06-2008 | 05:23 PM
  #325
Chip's Avatar
Chip
My original plan was just to run it in on these cams and start mapping it, then to swap to some hotter ones, but TBH based on how well its going so far, I think im probably going to stick with them, so I should have a good couple of thousand miles on them by the time its an issue for you. So I can soon whip the cam cover off and have a good inspection of the lifters to let you know how they have faired (not like it matters if the cams themsleves wear a bit quicker when they are cheaper to replace than an oil change is!)
Old 20-06-2008 | 07:12 AM
  #327
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Originally Posted by MAD YUM
Here is what its like at the moment
https://passionford.com/forum/showthread.php?t=244750
Looks like a mountain of work, good luck with it this time
Btw We found that several of my GT30 & 35 engines are on 99 blocks and not one failure, that includes Porkies which has been abused on track for about 4 years.
Old 20-06-2008 | 07:28 AM
  #329
Martin-Hadland
So does any of them use liners??
No, non. Porkie's bore is slightly bigger than yours too.
Old 20-06-2008 | 07:43 AM
  #331
Martin-Hadland
How many are running GT35 now? And get lots of abuse
Lee's ran a GT35 for 3 years but is now on a GT30, lot's of them have gone down to a 30. They will all be going for a GT32.5 soon
Old 20-06-2008 | 07:47 AM
  #332
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Tell us more .
Old 20-06-2008 | 07:48 AM
  #333
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Tell us more indeed Martin
Old 20-06-2008 | 07:57 AM
  #334
Martin-Hadland
Tell us more .
Automated message:
No further information is available at this time
Old 20-06-2008 | 07:59 AM
  #335
Franco's Avatar
Franco
Automated message:
Come on spill! and can mine be changed!
  #336
Cossie Helen's Avatar
Cossie Helen
Automated message:
Old 20-06-2008 | 08:01 AM
  #338
Mike Rainbird
Caraholic
Automated message:
Automated reply:
CUNT !
I'd make an educated guess that it is supposed to be a half way house between a GT35 and a GT30, so a true 550bhp turbo?
When will you have the airflow figures / first one to test?
Old 20-06-2008 | 08:02 AM
  #339
Turbosystems's Avatar
Turbosystems
Super Moderator
Automated message:
Mike would like to know the full spec so he can source them and put them on his web site and sell them for a tenner profit for his hobby and then moan that he makes no money out of selling parts
secret cams and secret turbos are the way forward
Old 20-06-2008 | 08:04 AM
  #340
Martin-Hadland
Mike can foxtrot oscar
Btw I'm just stamping up a load of standard cams with the special secret profile numbers, do you need any Tony?
Old 20-06-2008 | 08:06 AM
  #341
Mike Rainbird
Caraholic
Actually, I'm not a good enough businessman to do that, as I won't tread on other people's feet in this regard . Unfortunately for my wallet, I have too many scruples / morals....
Old 20-06-2008 | 08:07 AM
  #342
Dan's Avatar
Dan
Charming!
Old 20-06-2008 | 08:14 AM
  #343
Turbosystems
Super Moderator
that's not what harvey says lol
Old 20-06-2008 | 08:17 AM
  #344
Turbosystems
Super Moderator
Got a stack of standard cams myself good idea Martin I am thinking of calling them SSS (tripple S) cams,Secret Spec Standard lol
Old 20-06-2008 | 08:18 AM
  #345
CossieRich's Avatar
CossieRich
pmsl
Old 20-06-2008 | 08:34 AM
  #346
Mike Rainbird
Caraholic
I somehow don't think Harvey would complain about me stepping on his toes .
Old 20-06-2008 | 08:41 AM
  #347
CossieRich's Avatar
CossieRich
he doesnt complain about you doing him up the arse, so why would he complain about stepping on his toes
Old 20-06-2008 | 09:16 AM
  #348
Mike Rainbird
Caraholic
Now you know why I carry a milk crate around with me .
Old 20-06-2008 | 10:39 AM
  #349
LINCOLN's Avatar
LINCOLN
Lots of good info on this thread - you guys drinking too early in the morning?
I am currently enjoying a snifter or two of bourbon - but it's nearly nine at night.
Old 22-06-2008 | 05:32 PM
  #351
mechanic28's Avatar
mechanic28
are these genuine cams then?these SSS
Old 22-06-2008 | 05:36 PM
  #352
AJC's Avatar
AJC
the 'gt32.5 sounds interesting and certinaly some thing which i would think about,
Old 22-06-2008 | 06:16 PM
  #353
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Originally Posted by Chip
Yes.
by saying that Mark Shead can manage the "holy grail" of handling higher peak cylinder pressures without detonation, presumabley due to a better understanding of squish/piston design/cylidner heads, than all the "old school" tuners can muster
You have hit on a few truths there Mark cant beat the laws of Physics but he can & does get his engines nearer to optimum than the others you mention. He does give one of his silly grins when he hears the head/cam design of his rivals all working to 1980's rules. Unless they have a bit of lateral thinking they will never cure the surge/lack of torque problems.
It aint all Marks ideas but others tend to use the wrong fount of knowledge
Old 22-06-2008 | 06:29 PM
  #354
Martin-Hadland
Welcome back Rod
Old 22-06-2008 | 06:31 PM
  #355
mechanic28's Avatar
mechanic28
whats these cams all about then?or is it a wind-up?
Old 22-06-2008 | 09:24 PM
  #357
J1mbo's Avatar
J1mbo
B1mbo
what inlet is rod using ??
Old 22-06-2008 | 09:29 PM
  #359
J1mbo's Avatar
J1mbo
B1mbo
ahh ryt so would you use one if your inlet proved to be worse on the dyno ?
cheers
Quick Reply: Turkish block strikes again on YUM this time
