Turkish block strikes again on YUM this time
Old 17-06-2008, 09:25 AM
  #201
Edmund
Edmund's Avatar
I retract my post saying do not use liners,as i have just read you are high comp and use lots of boost.Maybe it would be wise to look into std non linered block and lower the compression,high compression and top speed doesnt really look good on paper for reliability,i know folk will quote Scandinavians and rallycross cars but these are NOT top speed cars.If you want to acheive your goal Mad Yum without any spanners you need to lower that compression or you are risking MORE failures.IMO.
Old 17-06-2008, 10:52 AM
  #202
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
how do you lower compression without spanners?
run water through the engine at high revs?
dont think thats going to be to successfull.
Old 17-06-2008, 12:01 PM
  #203
Edmund
Edmund's Avatar
If you could understand i said if he stays as it is he will need more spanners,the engine needs a rebuild now,do it once and do it right for his goal,then he wont need anymore spanners.
Old 17-06-2008, 07:21 PM
  #204
saph4be
saph4be's Avatar
i thought martin had retired from top speed runs now iirc
Old 17-06-2008, 07:52 PM
  #205
costina
Live long and prosper!!
costina's Avatar
Might sound daft but can u not use a std bore 200 block and liner that? u will end up with less cc's but it would be stronger
Paul
Old 17-06-2008, 07:57 PM
  #206
J1mbo
B1mbo
J1mbo's Avatar
Paul
do you mean standard bore size liners or am i goin mad lol
Old 17-06-2008, 08:14 PM
  #207
RWD Pete
RWD Pete's Avatar
Glad mines an old school 200 block
Bloody cossies
Old 18-06-2008, 07:23 AM
  #209
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Higher compression than all the others that recommend a standard block use - is that better for you?
Old 18-06-2008, 07:39 AM
  #211
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Just back from Le Mans Dave. Sorry to hear of this. Dont give in
Old 18-06-2008, 08:08 AM
  #212
Mike Rainbird
Caraholic
I thought that Mark quoted yours being 8.0:1 or possibly hinted at it being a bit more?
I was sure the MAD crew ridiculed 7.2:1 / T4s etc as being stuck in the past ?
Old 18-06-2008, 08:11 AM
  #213
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
I can't see any point in dragging all that up... Unless you are looking to start something off
Old 18-06-2008, 08:16 AM
  #215
CossieRich
CossieRich's Avatar
He cant help it
  #216
Mike Rainbird
Caraholic
Not at all, I was just commenting that I believed he should be sticking with a linered block due to the relatively high compression he was running compared to the advocates of an un-linered block. And then from Dave's comments, it appears that he is suggesting that the compression ratio isn't as high as previously claimed? Therefore, I was just trying to establish what the case was in a FRIENDLY bantering way (no more different from your "low boost" comment) .
Old 18-06-2008, 08:20 AM
  #217
Mike Rainbird
Caraholic
Okay, shoot me down in flames, but when-ever compression below 8.0:1 is suggested, the Rod comes on and tells us we are way behind the times and living in the past .
I was only trying to help, as in if you were 8.0:1, then all those people suggesting an unlinered block are living in cloud cuckoo land, and you should retain this set up for your engine, rather than listening to them .
Old 18-06-2008, 08:25 AM
  #219
Martin-Hadland
Originally Posted by MAD YUM
YUM has nothing to do with high compressions
Dave,
Do you know the c/r ?? Anything to slow Mr Rainbird down a bit!
I had assumed that your engine wasn't high comp anyway.
We have already seen that lowish comp can get you your goal
Old 18-06-2008, 08:29 AM
  #220
Mike Rainbird
Caraholic
Okay, I just thought that the way Rod goes on, that no MAD engine is below 8.0:1. My bad if that is not the case . However, I would still listen to Mark over anyone else about what block arrangement he considers safe for HIS engine....
Old 18-06-2008, 09:01 AM
  #222
jb fletch
MAD Carbon Cossie
jb fletch's Avatar
Was gonna say mine's 7.4:1 as well & is a MA Developments monster !
jb
Old 18-06-2008, 09:14 AM
  #223
Martin-Hadland
I can post now as we wont be using that compression ratio anymore
it was 7.4 but not going to say what the new spec is
Not interested in your new spec so you can have that back
Old 18-06-2008, 09:26 AM
  #225
Mike Rainbird
Caraholic
Well obviously it WILL NOW be 8.0:1 or more, as that is the current MAD way .
Old 18-06-2008, 09:31 AM
  #227
Mike Rainbird
Caraholic
Well Mark is obviously living in the past . Next you'll be telling us that T4s rock and that 80s music is the best .
Old 18-06-2008, 09:35 AM
  #228
Edmund
Edmund's Avatar
I retract everything i said on this post as i feel noone not even mad yum knows his own engine spec,leave it for your tuner is my advice and get a bloody warranty!
Old 18-06-2008, 10:03 AM
  #230
Chip
*** Sierra RS Custard ***
Chip's Avatar
Agreed
Old 18-06-2008, 10:21 AM
  #231
Mike Rainbird
Caraholic
I can't believe you numpties see it as anything other than backing up what MARK WANTS to do . I think it might be because I disagreed with the consensus that you're trying to score points?
I clearly and concisely clarified my reasoning for recommending linering the block, based on my understanding of how Mark likes to spec his engines. If you want to turn it into something else, feel free, but don't expect me to agree . I only back-tracked (with some playful banter - even taking the piss out my own views on compression and turbos ), as my assumption about the compression was incorrect.
Might I suggest you get a life rather than trying to stir shit where there is none . If I wanted to do that, I think I would do a better job than suggesting he gets Mark to decide on the block spec .
Old 18-06-2008, 10:33 AM
  #232
Chip
Chip's Avatar
Translation for anyone without the time to read Mike's full post:
Old 18-06-2008, 10:35 AM
  #233
foreigneRS
Testing the future
foreigneRS's Avatar
mike was clearly just having a bit of banter, can't believe people are trying to read anything more into it
Old 18-06-2008, 10:38 AM
  #235
JonnyBravo
JonnyBravo's Avatar
Thats how I read it too tbh, everyone is entitled to their own opinion but Mike was just having a laugh this time round
Old 18-06-2008, 10:48 AM
  #236
Mike Rainbird
Caraholic
Actually, I think you mean: or possibly:
Old 18-06-2008, 11:41 AM
  #237
pa_sjo
Colossal Pervert
pa_sjo's Avatar
As if arguing about compression ratios on the internet has any real impact to reality at all......
Old 18-06-2008, 11:49 AM
  #238
joffy
SLOW LEARNER
joffy's Avatar
is this passionford.com
or just passionforslaggingeachotheroff.com
Old 18-06-2008, 02:20 PM
  #239
Rab
Fucking superstar........
Rab's Avatar
Sell your Cossie and go Jap. Save all this hassle with turkish blocks and compression ratios and Mikes love of Ultravox.
Old 18-06-2008, 02:24 PM
  #240
Mike Rainbird
Caraholic
"Hymn" was the first EVER album I bought .
http://www.youtube.com/watch?v=mr7vWlRNR-o
Quick Reply: Turkish block strikes again on YUM this time
