chatter
Old Oct 29, 2004 | 11:36 AM
Hrsturbo's Avatar
Hrsturbo
Default chatter
Hi all, can standard S2 rs turbo's chatter cause I thought they couldn't?? I currently have a DV fitted but thinking about taking it off!
Old Oct 29, 2004 | 11:37 AM
Rhys's Avatar
Rhys
NO not really! the way they are. If u run lots of boost it will only be quite. Get cossie managment on there and hey presto
Old Oct 29, 2004 | 11:38 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
tHINK YOU NEED TO DO AWAY WITH THE AIR SENSOR THINGY THE FILTER GOES ON AINT IT??
Old Oct 29, 2004 | 11:40 AM
Rhys's Avatar
Rhys
Yeah mate the air fuel meter but onlt way to do that is by changing managment
Old Oct 29, 2004 | 11:41 AM
Paddy's Avatar
Paddy
Legend
I got a little bit of chatter on mine. take it to Karl Norris for a stage 1 tune, get rid of the dump valve and chatter comes free
Old Oct 29, 2004 | 11:43 AM
Jim Galbally's Avatar
Jim Galbally
it does, but its v.quiet..
theres a lot more to it techy-wise but thats all you relaly need to know...
if it chatters loud then its either not using KE-JETRONIC or you have a leak between the metering head + turbo (NOT good!)
Hrsturbo's Avatar
Hrsturbo
Don't know much about management so can you fit cossie management without changing to EFI?
And how much for that stage 1 tune up??
Old Oct 29, 2004 | 11:46 AM
Paddy's Avatar
Paddy
Legend
Jim, I'm not taking a leak on my engine for you again you sick fook.
Check out Karls site for prices and info:
http://www.norrismotorsport.co.uk
Old Oct 29, 2004 | 11:50 AM
Hrsturbo's Avatar
Hrsturbo
Had a quick look at the site but can't see any prices?
Old Oct 29, 2004 | 11:54 AM
KSA-Cossie's Avatar
KSA-Cossie
Mine runs k-jet,boosts at 18 psi and chatters.
Old Oct 29, 2004 | 11:57 AM
Paddy's Avatar
Paddy
Legend
You're better off ringing him or sending him an email.
The stage 1 includes: uprated actuator, 3 way bleed valve, custom chip/remap
He checks the car over thoroughly [trust me on this one ] and he maps the car live, sets up all the fueling and makes a good cup of tea too
It was Ł350 which I think is cheap as it tranformed my car from a grotty old RS to a 160bhp cossie killer. lol well it's quick anyway and the torque figure was awesome.
I know there's loads of other tuners out there, Stu [motorsport developments]does a similar set-up, power engineering could probably do it too, depends how far you want to travel. I travelled a few miles to karls and wasn't disappointed.
It's definitely worth getting one of them to check it over and set it up though
Old Oct 29, 2004 | 12:08 PM
JesseT's Avatar
JesseT
Mine chatters at any boost and it's doing my head in. Any recommendations on how to make it totally quiet are welcome...
Old Oct 29, 2004 | 12:52 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
The RS Turbo (as with ANY turbo car) Chatters as you close the throttle. However, because the return path of the air goes through the Metering head, it loses its volume. You will hear it on most RST's to a greater or lesser degree and more so as you increase the boost. You will also hear it more with an Induction kit (however, the Standard Airbox is the best option!!)
To fit alternative management just to be able to hear chatter is ridiculous IMO, but we would happily sell you an Omex system if you want!!
Fit a Dump Valve!!
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
mines on KE and 7psi and it chatters
Old Oct 29, 2004 | 12:56 PM
Paddy's Avatar
Paddy
Legend
put your fingers in your ears when you come off throttle.
Old Oct 29, 2004 | 12:58 PM
Christian and Beccy
#1 in Spelling Club
I have a better idea. Take the turbo off and remove the blades with a set of Snips. Then it won't chatter.
Old Oct 29, 2004 | 01:00 PM
Paddy's Avatar
Paddy
Legend
I never thought of that.
I bet Jim did.
Old Oct 29, 2004 | 01:05 PM
Oranoco's Avatar
Oranoco
Mines on KE-Jetronic and at 25psi it chatters a bit.
Throw your DV in the nearest skip mate it may not chatter but the car will run a lot better
Old Oct 29, 2004 | 01:07 PM
timrud's Avatar
timrud
Buy a Mk5 RS2000, I hear they chatter pritty quietly
Old Oct 29, 2004 | 01:10 PM
Paddy's Avatar
Paddy
Legend
Throw it on ebay.
Someone with a saxo will buy it and claim it makes their car faster.
Old Oct 29, 2004 | 02:24 PM
mattbibs's Avatar
mattbibs
Old Oct 29, 2004 | 02:32 PM
cossiemen's Avatar
cossiemen
Whassup
so any turbo'd Ford running on standard boost won't chatter?
as for my standard cosworth engine it won't chatter without upraising the boost?
Old Oct 29, 2004 | 02:33 PM
mattbibs's Avatar
mattbibs
fiesta turbo's chatter pretty well from my experience!
pretty sure cosworths will chatter at standard boost - its just those escort turbo's with crappy MFi!!
Old Oct 29, 2004 | 02:34 PM
vroooom ptssssh
It Wasnt Me!
cossieman, mines is std on std boost and it does...it's just luck i think? lol
Paddy's Avatar
Paddy
Legend
don't standard cossies have a blanked off dump valve?
Old Oct 29, 2004 | 02:38 PM
cossiemen's Avatar
cossiemen
Whassup
think so, but i'm not sure
Old Oct 29, 2004 | 02:43 PM
Paddy's Avatar
Paddy
Legend
I thought I read somewhere that they did mate, could be a reason behind no chatter.
Old Oct 29, 2004 | 02:46 PM
vroooom ptssssh
It Wasnt Me!
std cossies got a recirc dump valve, take it off and blank airbox-turbo hose and blank off ic
Old Oct 29, 2004 | 02:47 PM
cossiemen's Avatar
cossiemen
Whassup
never realy given it a try
Old Oct 29, 2004 | 02:49 PM
cossiemen's Avatar
cossiemen
Whassup
cheeRS mate, but what does ic means??
Old Oct 29, 2004 | 02:51 PM
steve rs's Avatar
steve rs
my Series one used to chatter really loud just didn't last very long.
Standard Cossies will chatter with an induction kit my mates 3 door sounds
quite good it is only running 7 psi
Old Oct 29, 2004 | 02:55 PM
mattbibs's Avatar
mattbibs
ic means intercooler dude!
vroooom ptssssh
It Wasnt Me!
Ic means Inter Cooler
Old Oct 29, 2004 | 03:03 PM
cossiemen's Avatar
cossiemen
Whassup
okay guys, now i got it
so i'm gonna give it a try tonight
took a while before i've knew what IC means but that's what you have with
those fookin stupid foreign goons
Old Oct 29, 2004 | 03:06 PM
vroooom ptssssh
It Wasnt Me!
Old Oct 29, 2004 | 03:07 PM
mattbibs's Avatar
mattbibs
stop insulting him - scotland is only just foreign!!
Old Oct 29, 2004 | 03:32 PM
vroooom ptssssh
It Wasnt Me!
oiiiiiiiiii
Old Oct 29, 2004 | 03:42 PM
cossiemen's Avatar
cossiemen
Whassup
well, i got pretty well away with it
Old Oct 29, 2004 | 03:46 PM
cossiemen's Avatar
cossiemen
Whassup
and what to do with the hose that goes from recirc dump valve to plenum chamber? i suppose i have too blank it off too??
Old Oct 29, 2004 | 08:48 PM
cossiemen's Avatar
cossiemen
Whassup
yep, i have to blank it off too
just read another post about dumpvalves on saphh's.
https://passionford.com/forum/viewtopic.php?t=80907
Chas
Sep 21, 2015 08:57 PM
nice_head
76
Aug 22, 2005 09:17 AM
thelynx
Feb 26, 2005 10:33 PM
DaveRS
Feb 3, 2005 04:59 PM
MadMac
56
Jan 7, 2005 09:09 PM
