Why is it...
Old Oct 29, 2004 | 11:07 AM
Daveyboy's Avatar
Daveyboy
Default Why is it...
...that every time its wet outside, as soon as i open my window and turn a corner my right leg, arm and door trim gets absolutely soaked from the water on the car does my tits in!!
Surely if Ford can put together a car like a cossie, they could have at least sorted out some sort of fookin drainage for this!!
am getting pissed off coming to work half soaked everyday!
Old Oct 29, 2004 | 11:11 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
CLOSE THE WINDOW..........................
Spiky's Avatar
Spiky
dont turn, drive straight
Lou Lou.'s Avatar
Lou Lou.
mine does the same
just keep ur window shut then open the passenger 1
Old Oct 29, 2004 | 11:14 AM
Nath's Avatar
Nath
I get the same thing in the Bm, its even worse on some cars when you do the washers, then 2 wipes later on the wipers and you smell of screen wash. I reckon they should make it cherry flavored for some cars
Old Oct 29, 2004 | 11:15 AM
Cola's Avatar
Cola
pmsl @ that
Noooo! That's MY side
Davey, if you insist on buying a cut and shut this is what will happen x
Daveyboy's Avatar
Daveyboy
kinda defeats the purpose of having a window then doesnt it!
your old saph is proof enough NOT to take your advice Spiky
coming bowling? you know ya wanna
Old Oct 29, 2004 | 11:17 AM
Daveyboy's Avatar
Daveyboy
so why didnt you say anything when we went to buy it babe? x
Old Oct 29, 2004 | 11:18 AM
Lou Lou.'s Avatar
Lou Lou.
sorry huni
sunroof then??
Old Oct 29, 2004 | 11:20 AM
Spiky's Avatar
Spiky
my saff?? nothing wrong with it...... note, please only look at front wing
as for bowling, i'm well up for it, but need to ask the boss
Old Oct 29, 2004 | 11:22 AM
Daveyboy's Avatar
Daveyboy
boss has just given you the ok dude!! what time you gotta be home?
Old Oct 29, 2004 | 11:25 AM
Spiky's Avatar
Spiky
she's the boss, so i guess when i can no longer walk or talk,
unless i'm driving
baaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaabbe you driving
Old Oct 29, 2004 | 11:34 AM
Oranoco's Avatar
Oranoco
My A4 does that.
I solved it by throwing the car about a bit when I first leave to shift the standing water and then winding the window down a bit
Old Oct 29, 2004 | 12:06 PM
Scottish Greg's Avatar
Scottish Greg
FRST's are the same Davey ......
the trick is leave window shut ...... move off .... then brake quite hard, all the water will run forward and not soak you. Then open your window
Old Oct 29, 2004 | 12:10 PM
Daveyboy's Avatar
Daveyboy
if i brake hard at the moment my caliper will fall off
Old Oct 29, 2004 | 12:13 PM
Scottish Greg
is that due to dodgy W & D garage services ??
Old Oct 29, 2004 | 12:17 PM
James_RScos's Avatar
James_RScos
My fiesta does it i keep the window shut for a bit until the water has run off then open it. sorted
slammedorion
21
Aug 6, 2015 11:38 AM
Skiman
Jan 11, 2005 03:31 PM
CabrioTurbo
Dec 8, 2004 01:26 PM
neilm
Nov 7, 2004 01:39 PM
Jim Galbally
Nov 1, 2004 08:30 AM
