were can i get a trigger wheel for cossie runninf emerald
36-1 TEETH, 5 1/4" diametre,
trigger-wheels.com, about £25 off ebay.
You can use 60-2 teeth as well , but 36-1 much more common.
The rear edge of the missing tooth needs lining up at 90 degrees(BTDC), although it can run in any position at all, if so desired
2wd ones normally fall off, you will also need a TACHO DRIVER(if using std tacho) as it will also be coilpack, and very unlikely to work from the coilpack signal.
You will also need a WIDEBAND LAMBDA(= fitting) and EGT sensor, as it can run purely on EGT once mapped as a lot safer.
I can knock you up a sensor boss for lambda/egt as I now have a lathe.
The EGT will come with a signal convertor if using a AUDI 1.8T one which are very good, also a signal processor for the lambda such as TECH EDGE.
I've got coilpacks you can have FOC, Matt L does the leads.
You can dispense with the phase sensor and go with batch fired for track work.
JK12
33
26-04-2021 12:09 PM
3dr cossie
21
20-11-2015 05:00 PM
