General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
dont think so mate altho i may be corrected, dont forget fuelling needs to be good not just on full power. for example my 450+ saff on 83's fuel's nicely all the time not just on full chat.
As above, looking for some Siemens Blacks to replace my greys, only need them for around the 400bhp mark.
I understand 55lb would be ideal but will 83lb be ok too? Is there a problem with them being so big? cheers
should be fine if you have an ecu that can control them well...
i have theses on my Escort with an autronic SM4, although i have lowed the fuel pressure to 3 bar static to help the idle, but even at 3bar rail pressure there only at 1% duty at idle..
will be fine mate if set up correctly, you might as well get the 83lb as that way you've have future proof'd the injectors in case you want to increase power later on
It really depends on the particular injector... in the case of the 'siemens blacks', then 83lb will probably be ok as they are quite manageable.. i'd go for the 55's though, would give superior control/emissions.. it's not hard to change to bigger ones in the future.
I only really want it for better fuel comsumption to go with the closed loop it will be going on shortly.
Sounds like 55lb are the better options in which case.
Cheers fellas
