Changing a focus headlight
can someone advise this dude on my forum please?
http://www.girlracer.me.uk/viewtopic.php?f=5&t=8714
you need the grill off and the corner of the bumper dropping down on which ever side you are doing. There is a bolt under where the corner of the bumper is. There are also 2 10mm screws on top of the head light.
All perves searching the members list for pics then...
Can't open the page, but I'm assuming you just want to change the headlights over? Then its a basic case of disconnecting the multiplugs in the back of the pods, then unscrewing the 10mm screw that secures it to the inner wing, the 10mm that holds the centre in place, and then you need to jack the car up to get at the 10mm screw that holds the base of the pod in its place. This screw faces outwards.
Just reach underneath the bumper to get acces to the bolt, no need to drop the bumper down.
Then two bolts on top, and pull it forwards, off it comes.
JK12
33
Apr 26, 2021 12:09 PM
