Dizzy retard question
My mate has fitted twin turbos to a 2.9 v6,he got himself a micro dynamics boost retard box but its not compatible with the ford ecu.
So he's stuck atm,i had the idea of using a boost pressure switch which he has,and is adjustable and switches to earth to control the ecu retard octane wires which are found on most ford ecu's if i remember you can earth either one or the two wires to obtain retard
CAN this be used to get him out of the S**t for the mo????
or any other ideas would be helpfull
Paul
Paul
You could move the CPS position to retard, then use a WOLF N3D spark advance unit to get back correct, cutting power would let it drop back again, maybe power it through a micro switch on the throttle ?
Testing the future
The car will only run a max of 8 psi atm with a shed load of fuel aswell
so imo i think it will be safe enought till he gets a proper ecu?? if the dizzy is mechanically moved to give more retard can that work ??
Any more suggestions will be great
Ta
Paul
Testing the future
might be enough paul, but you'll only know by checking
a friend of mine runs a pinto 2.0 efi with a t3 on it in a mk1 transit tipper and uses a pressure switch to ground out the octane adjusters on that and it works well without det.
the 2.9 has quite low compression ratio as std doesn't it?
intercooling is very important though, the cooler the charge, the better chance it has of not detting with only that much retard.
give it a go using super unleaded, what's the worst that can happen? it's only a boat anchor anyway
So should be ok we will have to see
Paul
LPG dealers.
These are Itaian made units, by EFI I think(not 100% sure though) but are excelelnt.
I have one so could dig it out and give the part numbers etc if you like ?
My mistake the unit is made by AEB. re Italy
Called a TIMING ADVANCE PROCESSOR, "wolf n" MOD BREVATTATO.
I have just changed ISP's to plusnet, not quite sure how to do piccies but PM me your email and I will send you a few piccies of the unit.
It measures 4 x 3 x 1 1/4 inches
