dawes divice .......
these any good ,i know some of the evo guys use them,
im running my actuator direct to the compressor housing using pre-load to set the boost,
on my focus RS, is this the rigth way to be adjusting the boost or should i try a mbc
IIRC a bleed valve bleeds to atmosphere. Dawes is just like a restrictor valve in between actuator and compressor, you can open/close it to adjust boost it, doesnt actually bleed off. Thats my understanding anyway, but Ive not had much to do with either so I could be wrong.
Testing the future
not that crude - more sophisticated than a bleed valve as they hold a pressure regardless of ambient conditions.
obviously the ecu has no control though, so if you have a scenario where something has gone wrong, perhaps a sensor failure, then the ecu cannot reduce boost to protect the engine from potential damage
also, you cannot create a useful midrange torque spike with something like a dawes device
Twistin me melon man
i had a dawes device on my old mondeo 1.8TD. it wasnt really an engine worth spending Ł250 on a fancy electronic one, and it had no ECU anyway.
i originally had a normal bleed valve on it and it was OK, but i was recommended to use a dawes device instead because they are good on diesels, and it was better than the old bleed valve in that it didnt spike so bad.
bleed valves are crude, but they do work!
1 Post
i had one on my evo 6 with the ralliart sport ecu, and worked quite nicely,
no there wasn't any mid range boost spike, but it did maintain boost well right through the rev range .
Yep, dawes is good... better than most electronic boost controllers. Mine just flies up to it's target boost with no spiking, which is more than I can say for a lot of EBC's I've used.
As others have stated they are not a bleed valve (which is crap) they are a ball and spring design and don't bleed off air. Bleed valves give very poor spool in comparrison.
*** Sierra RS Custard ***
So its not really "bleeding off" air.
They are a bleed ON device, like air injectors if you want to think of them in terms other than just as a dawes device.
Graceland
23
26-03-2006 06:12 PM
cfoster
26-12-2005 10:46 PM
Adam_BlackRS
22-12-2005 01:44 PM
