"Clunk" when braking (4x4 saph)
Whats brakes?
Pads not locating correct in the carrier?
Loose caliper/carrier bolts?
You can normally aggrevate them by reversing then braking then forward and braking and so on. Noticeable when you doing your 20 point turns trying to get into a car park at ASDA.
Where is the clunk from or feel/sound like its from ? Front / rear ?
Metallic, tinny, solid dull thud etc - throw us a clue,as it could be any mounting (gearbox/engine etc) or bush / tca / bearing.
Does it do it on braking whilst turning or only on straights etc ??
Pad rattle can be sorted on any car by fitting a residual valve if it's that
Copper greasing can help dampen noise (squeal) but generally not help with rattle.
I had this mate
on my escort
loud clunk when braking (only 1st time tho) 2nd time a lot quieter .. now the weather has got warmer, doesnt do it at all....
Wierd...
on my escort
Wierd...
i've got a dull thud that comes above half a second after letting off the throttle at low speeds, pretty sure its coming from around the rear diff area, any idea on what it could be, and what causing it?
Team HOTHOT!
I had a similar clunk Kev just when turning to the rights slowly, like round a tight corner or a small roundabout or something, turned out it was the exhaust knocking
gracey, is this normal? or does it mean the the diff needs looking at
pps:
i thought it was that, but not a clue what causes it and why its suddenly started happening, maybe its always been there but never noticed it.
![Embarrassment](https://passionford.com/forum/images/smilies/redface.gif)
The Enigma
12-09-2015 10:12 PM
dojj
28
11-09-2015 10:00 PM
truffleshuffle
10-09-2015 09:35 PM
