bit of shopping... where to get the following pls?
can anyone help me find the cheapest place(s) to get the following for my escort?
alloy rad for use with a zetec, (ie inlet and outlet ont he same side), preferably that fits in the standard gap so i don't have to mess about getting it in there) - (maybe radtec unless someone knows of a cheaper one?)
ashley exhaust manifold for zetec in a mk2
alloy front hubs and associated bearings as my hubs/bearings got fucked in the garage flood)
fuel cell (about 10 gallons should be plenty was looking at Jaz probably - gave up on the ATL - ££££££££££££££££££££££££)
poly bush set for front end of mk2 escort
quick shift gear lever for a type 9
window and door seals (guessing probably east kent trim is the only option here?)
polycarbonate window set with sliders
a whole load of nuts and bolts suitable for refitting my cage as most of them seem to have magically disappeared
also... is rubber fuel hose suitable for use inside the car, as I don't really want to go the whole hog braided stuff just yet. going to save that until i need a high pressure fuel feed for my next engine.
thank you very much!
TPM961
15-01-2018 10:50 AM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
