Tracking
Old May 18, 2008 | 02:54 PM
BM08's Avatar
BM08
Default Tracking
Bit of a stupid question but when you have tracking done what exactly do they do?
Old May 18, 2008 | 03:05 PM
user 769729789's Avatar
user 769729789
It makes sure all your wheels are pointing the same way essentially.
Old May 18, 2008 | 03:10 PM
BM08's Avatar
BM08
yeah i know that but what exactly do they do in the process?
Does the machine do all the altering
Old May 18, 2008 | 03:57 PM
Thrush's Avatar
Thrush
Irritating c........
People do the adjusting, machine is an alignment tool
Old May 18, 2008 | 04:06 PM
Westy's Avatar
Westy
yes, the machines are very advanced and can do all the adjustments by itself...
how many mm in a cm :cry
Old May 18, 2008 | 04:19 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
depends on the car, on most older fords.
The little elves loosen off the locking nut on the steering rack tie rod ends (on the end of the rack bolted to the hub) and wind the tie rods to lengthen (or shorten depending on toe in or out) the rod exposed then do the nut back up to lock the tie rod end up.
you can also correct your steering if its off center a little bit by winding them both the same way
Old May 18, 2008 | 04:42 PM
babscossie's Avatar
babscossie
Do i detect a hint of sarcasm in there somewhere boys. Ever thought that not everyones life revolves around a car.
Old May 18, 2008 | 04:51 PM
BM08's Avatar
BM08
Thanks, but i know theres some sarcy barstewards on this site, i just ignore it and read the answers that are actually helpful
Old May 18, 2008 | 04:54 PM
mrjenrst's Avatar
mrjenrst
No why would you think of such bollocks like that
Old May 18, 2008 | 05:02 PM
BM08's Avatar
BM08
some people, clearly
ossie cossie
57
Nov 21, 2022 10:05 AM
gingeRS
17
Oct 2, 2015 09:42 AM
muzzman1
Sep 30, 2015 08:59 PM
SMILER258
Sep 28, 2015 09:04 AM
ossie cossie
Sep 21, 2015 05:07 PM
