What suspension
For a MK5 rs2k, my car has been fully rebuilt and im now in need of some suspension what have people tried and tested and what can you recomend im thinking a koni pakage as so far ive heard no compliants.. any ideas?
nah wont be going on track pete, but i want some decent suspension on it not sure how much it should be lowered either ill be putting 17" wheels on it..
Coilovers are so called as the coil(SPRING) goes over the shock body.
They have adjustable platforms so that you can adjust the height of the collar so the car will sit lower or higher as desired.
Damping is adjustable too on these, but they ARE more money.
spax are good suspension wise imo, but theyre quite a harsh ride even though theyve got adjustable damping.
i think given the choice with any car id pick coilovers, at least you can adjust the height if your not happy with it for any reason, tho with fixed suspension your stuck really.
Sarah
Sarah
i just want something that'll handle decent aswell as look good with the 17" wheels doesnt have to be the best there is.
as above you can use normal kits or coilovers for on road aswell.
Ive had Gmax on my old Escort and got a full Bilstein kit on my Golf and the ride is about the same but handling is better, and they are a better built kit.
If you go for a normal kit make sure its 60mm at least, otherwise it wont look like you have lowered it if its 40mm.
I wouldn't say the coilovers are harsh at all.
I have just put brand new suspension on my g/f astra eibach springs with bilstein dampers, and it is very good, os so Ithought until I got my rear coilovers refurbbed by AVO(£67/pair all in).
I am using these on ZERO setting on front with 2 turns on the rear, it is AWSOME, so comfy.
Comparing it to the astra it is WAY better, and comparing it to my dads mk1 mondeo GHIA, it is still WAY more comfy.
Sorry I, would not swap my AVO for any other suspension, have had KONI/SPAX/BILSTEIN/G MAX etc, nothing comes close, nowhere near it.
SMILER258
28-09-2015 09:04 AM
