RS Turbo Problems-Posting of behalf of a friend
**Also In Technical**
Escort RS turbo feb 88 (E) reg.
Vehicle starts ok from cold but dies after a sencond or two, but will re start no problems and then run the cold start process perfectly. But once warm up cycle is complete & the car gets hot, the car will not start or starts only with great difficulty when switched off. (Not instantly but if swiched off and left for over 5 mins). Seems to be starved of fuel or evaporating
Vehicle is standard bar Mongoose exhaust & K&N panel filter,very well maintained, has covered 126K but runs superb.
Items replaced,All genuine Ford components. (in order of doing so).
Eng fuel pump relay, eng temp sensor & thermo time switch.
Air bypass valve & throttle potensiometer.
Cold start injector & air temp sensor.
Fuel accumulator, pressure regulator & main fuel pump.
Fuel filter & fuel treatment.
BACKGROUND INFO.
Fuel metering unit with ecu & spark map ecu fitted just over three years ago, Co'2 set correctly. Distributor replaced two years ago due to total but unrelated failure.
HELP!! Any idea's
BACKGROUND INFO.
HELP!! Any idea's
JK12
33
26-04-2021 12:09 PM
slammedorion
15
01-11-2015 07:17 PM
Matt Baxter
16-09-2015 08:30 PM
