Max boost reading on secs monitor ?
15-05-2008, 08:25 PM
Is it 28 psi ?
15-05-2008, 08:26 PM
It should be max of the 3 BAR map sensor
So 1 BAR atmospheric, 2 BAR boost, so 2 BAR
But I seem to remember seeing 33psi on ours at some point
15-05-2008, 08:28 PM
Thats what i thought james,but you can set the alarm up to 32 psi ??
15-05-2008, 08:55 PM
Passion for Fords!
mine reads up to 28ish, simon did say he could make them run a 5bar sensor....
15-05-2008, 09:00 PM
I think I saw Trev's peak at 30psi!?
15-05-2008, 09:04 PM
Passion for Fords!
15-05-2008, 09:05 PM
Nope, it isn't!
15-05-2008, 09:06 PM
15-05-2008, 09:07 PM
Fairly sure, would have to ask Trev but i'm sure I remember seeing it read 30psi when he took me out on his old T34 setup last year!
15-05-2008, 09:08 PM
Mine won't read past 28.4
15-05-2008, 09:12 PM
Ask Trev to be sure mate, mine aint in the car yet so can't tell you but at MSD it's only been set for 24psi anyway so won't peak past the monitor's capabilties
15-05-2008, 09:13 PM
Passion for Fords!
i think tbh, map sensors vary a tad, but 2 bar is below 30psi, so 28.4 i would class as normall, same as mine
doesnt help me at all when im running the t4 at 40psi....which is why i want it 5bar sensored
15-05-2008, 09:19 PM
29.4 PSI isnt it 2 Bar? spot on what my mates chimed up at - 29PSI odd., are they not adjustable past that then or is that the V.MAX?
15-05-2008, 09:23 PM
Passion for Fords!
well the map sensor should output 5v at 2bar...which is its peak reading...
timsrs
13-11-2018 11:48 AM
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
