rs turbo issue
got an oil pressure problem ... rebuilt engine and has low oil pressure on idle .. low enough to bring on the your engine is fucked light....
this is the second oil pump fitted to the car .. on normal driving or reving it appears to be fine as the light goes out... has also had a new pressure switch fitted ...
any ideas???
any ideas???
Abit more info would help,
what oil is being used,
what oil temp,
what oil pressure and rpm's?
Have you tested your oil pressure switch light, to see what pressure is goes out?
what oil temp,
it ticks over nicely, no idea on oil temps as no guage fitted..or oil pressure guage ...
on normal driving it sounds ok not tappety or anything ... just the light comes on at tickover.. new sender was fitted to check .. as for what oil is in there i will check the can...
cheers dan.
cheers dan.
Did you check the big end and mains bearing measurements before the engine went back together? Or did you just assume the engineer got it all ok? Most do, I nearly put a fiat engine together and the plastigauge wasnt reading right. Turned out to be standard shells in .25 undersize box!
Just a suggestion? Are you getting oil pumping through the turbo oil feed pipe? Did you pack the pump with vasealine before it was fitted? Pump might not be priming/primed.
Pump has to be primed as the engine owuld be seized already.
Oil grade is ok?.....with a fresh build are you on mineral/run in oil? Thats normally piss thin to start with nevermind when its hot.
Other than that bearing tolernaces could be an issue, saying that if the pressure is low enough to bring the light on i'd expect to hear some angry tappets.
Could it be shit on the pick up pipe from the sump? Dirty engine build, fresh oil pushing loose shit into the sump and then blocking the gauze? You deffo have the correct oil filter?
Best pressure check the sender unit, or fit a oil pressure gauge to the car see what heppening. (a hour job to fit and test at most if you have a spare capilery oil pressure gauge and fittings.)
As mention'd, 15-40 minerial oil, will show lower oil pressure than a 10-40 semi at the same oil temp.
Matt Baxter
16-09-2015 08:30 PM
gchristophi
31-08-2015 10:36 PM
siscossie
27-08-2015 09:27 PM
Red_bull
09-08-2015 08:34 AM
