Rolling road tomorrow
Old 16-05-2008, 06:39 PM
  #41
RWD Pete
RWD Pete's Avatar
Originally Posted by costina
Pete are you using std cam pulleys?if yes get a set of verniers and dial the cams in to perfection
on my old pinto efi i gained 28bhp for 1 mm of cam movement
The bd 14 i was told it would gain bhp but lose torque
Paul
cams are dialled in buddy to kent cams recomendations
i am hoping the 15 inlet and 14 exhaust combo will make use of the heavily ported head
Old 16-05-2008, 06:40 PM
  #42
RWD Pete
RWD Pete's Avatar
Originally Posted by cossie4i
So why am i such a show off and cheeky then Pete ???????
Steve.
The smile will be on my face at the end of this month
I'll put a quid on it?
Old 16-05-2008, 09:05 PM
  #43
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Will you be taking the car back to the same RR when you have done the cams Pete ?
Did you have a flywheel figure from the last RR session ?
Steve.
Old 17-05-2008, 08:21 AM
  #44
RWD Pete
RWD Pete's Avatar
Steve.
Yeah will be going back to art he's a good lad doesnt charge a lot even tho he has just spent £1000's on a new rolling road.
Cam should be here on monday then im gonna see how it goes with chip i have, if its not right then motorsport developments want £100 for a adjustment on chip
Old 17-05-2008, 08:22 AM
  #45
costina
Live long and prosper!!
costina's Avatar
U will need a new chip or a live map if you change the cams again!!
I dialled mine aswell but was still offonly real way is on a rolling road imo
Paul
Old 17-05-2008, 08:52 AM
  #46
RWD Pete
RWD Pete's Avatar
Thats what i thought paul but tony (local tuner) says out of the thousands of times he has done it on rollers theres usualy little or no point in changing from what the manufacture recomends as theres no real gain or the gains in power looses torque
Old 17-05-2008, 08:53 AM
  #47
RWD Pete
RWD Pete's Avatar
Rev limit may need adjusting too
boeb
09-01-2020 05:11 AM
07-10-2015 12:56 PM
mk22door
23
02-10-2015 10:06 PM
AJC
01-10-2015 06:47 PM
Mikersturbo
27-09-2015 07:43 PM
Quick Reply: Rolling road tomorrow
