Rolling road tomorrow
13-05-2008, 06:37 PM
Just need to work my avcr out then its off to art for a run or seven.
Gonna wind the boost up as far as i can go and im hoping for at least 420.
Its running TT T38
Ported head by me
BD14 inlet
STD exhaust cam
2wd exhaust manifold
4x4 inlet
7.2:1 cosworth pistons
865cc siemens injectors
044 pump
Mr stu chip
Did run it at 32 psi last monday and it felt very strong that was via bleed valve
So tomorrow some proper boost control and a fine adjustment of fueling should hopefully make some good power.
Now covered 350 miles and its seen boost from 2 miles.
Trying the brake it in hard aproach.
Reason: summer is over
13-05-2008, 07:57 PM
TT T38 Power
All the best for tomorrow Pete
I posted my 1/4 times on your other thread.
Steve.
13-05-2008, 08:01 PM
Unknown.
Where are you getting it RR'd?
Good luck
13-05-2008, 09:26 PM
Best of luck with it fella, if you are running 2 bar plus I'd be surprised if you didn't see that.
Can you adjust the boost on an off the shelf chip? Surely it'll need live mapping or a custom chip to suit?
13-05-2008, 09:31 PM
nothing wrong with bleed valves mate,hope it produces the numbers for you
14-05-2008, 04:43 AM
good luck mate hope it all goes good for you.let us know the figures
14-05-2008, 01:58 PM
TT T38 Power
You got any results then Pete ???
Hope all went well mate
Steve.
14-05-2008, 02:07 PM
Live long and prosper!!
446 bhp and 400 lb ft
Thats my guess
Paul
14-05-2008, 02:27 PM
TT T38 Power
Quote:
Originally Posted by
costina
Thats my guess
Paul
Pete would be well happy with that im sure
But going from his 1/4 mile times he ain't got that unless he turned the boost up. His car put on just .23mph more than mine over the last 1/8th and i only have 372bhp.
Steve.
14-05-2008, 02:50 PM
costina
Thats my guess
Paul
On a T38? I recon more like 440BHP and 360ish Lbs/ft, for some reason T38's make crap torque compared to a T34.
14-05-2008, 05:30 PM
cossie4i
Steve.
Your car is lighter than a saff
and all those years at the traffic lights in you cortina paid off for you good starts
Paul
14-05-2008, 06:23 PM
saff is working!!!...atm
RWD_cossie_wil
............this is why R/R's are shite...................mine made 390ft/lbs at only a 27psi spike...............
14-05-2008, 06:27 PM
TT T38 Power
costina
Paul
I can't see how the 4i is lighter than a saph, must only be a few kgs in it ?
I gave the last 1/8th because traction is not a issue, at the 1/8th we was only .07mph different. So it's all down to power for that last 1/8th.
Steve.
14-05-2008, 06:29 PM
pete mcrash
What RR though?
14-05-2008, 06:30 PM
Unknown.
If its EA rollers, He'll have 500bhp
14-05-2008, 06:34 PM
(i ment it to sound as u ment it)............i made 370 ft/lbs at well lane @ 26psi......and 390ft/lbs on dastek rollers @ 27psi.........
14-05-2008, 08:19 PM
TT T38 Power
I hope you ain't blown it up Pete
Steve.
14-05-2008, 10:48 PM
right lads i did it on my locl tuners very realistic non "happy" rolling road and she made after a slight fueling tweak 384 at the wheels at 5900 rpm at 30 psi held.
now im gonna increase boost to 34 and deresrict exhaust as it has a silly restricivr middle section, we decided fuelling was good via stu chip but a live map would perfect it, with more boost and exhaust mod maybe 400 at wheels eh
im happy tho for what i have spent
14-05-2008, 10:50 PM
cossie4i
Steve.
No mate its very healthy hopefully ill bump into you this year
lads take piss cos its so rough looking haha but thats the idea
14-05-2008, 11:16 PM
14-05-2008, 11:18 PM
mate thats an awful pic
15-05-2008, 04:52 AM
TT T38 Power
Pete, that bloody graph is crap. I can't read a thing.
Mine made 316bhp @ wheels on a Dyno Dynamics RR with 372bhp flywheel figure, so with your 384 @ wheels that should be about 440bhp flywheel
What torque did it make ?
Turbo works well then
Steve.
15-05-2008, 08:08 AM
oh yes it sure does, torque was 351 lb ft only problem is my apexi seems to max out at 30 psi
15-05-2008, 08:10 AM
not the best pic i were slightly pissed last night
15-05-2008, 08:16 AM
costina
Thats my guess
Paul
Wish i had torque like that paul, mine doesnt start winding up untill 4000 rpm its like a friggin motox bike
15-05-2008, 02:19 PM
Still your near your figure so thats good 400 atw is a good fun car
Nice one pete for a home built motor
15-05-2008, 02:20 PM
cheers paul im happy for now, just finished my last job so im gonna do some more running in miles
15-05-2008, 02:36 PM
15-05-2008, 02:47 PM
cheers mate
only problem is its so top endy nothing down bellow
what do you lot think a gt30 would do to the characteristics
15-05-2008, 02:52 PM
15-05-2008, 03:52 PM
TT T38 Power
RWD Pete
cheers mate
I will give you Ł500 for your T38
Steve.
15-05-2008, 03:56 PM
TT T38 Power
Just seen your sig Pete LOL, keep trying
Steve.
15-05-2008, 04:03 PM
TT T38 Power
RWD Pete
Mine also made 351lb/ft
But mine was only at 24.7psi
Steve.
15-05-2008, 04:53 PM
RWD Pete
cheers mate
Probably make it worse!
16-05-2008, 08:11 AM
Steve your such a show off and very cheeky too
Ordering another cam today, im gonna swap my 14 inlet to the exhaust side and order a bd15 inlet cam.
16-05-2008, 08:21 AM
RWD Pete
Thats correct mate they do top out at around 2BAR unfortunately!
16-05-2008, 08:34 AM
wonder if theres any way i can trick it with a bleed valve hmmmm
16-05-2008, 12:15 PM
Pete are you using std cam pulleys?if yes get a set of verniers and dial the cams in to perfection
on my old pinto efi i gained 28bhp for 1 mm of cam movement
The bd 14 i was told it would gain bhp but lose torque
Paul
16-05-2008, 12:49 PM
RWD Pete
If you did it would have a tendency to spike wont it!
16-05-2008, 03:47 PM
TT T38 Power
RWD Pete
So why am i such a show off and cheeky then Pete ???????
Steve.
