Steam cleaning?
got silver leathe rin my E36, the alpina ones. thing is, my interior smells musty and old.
ive bought a little steam cleaner from ebay and was wondering if steam cleaning the leather will damage it?
also, will steam cleaning the carpets help towards getting rid of this musty smell?
any tips on removing this smell?
best bet, take all the seats, carpet underlay etc out.
clean all the dash plastics etc
then shampoo hoover and steam clean the carpet and underlay and leave them in the sun to dry and air out, then do the same with the seats
then refit it all...musty smell gone
p.s. as a tip while the interior is out. run a hose over the bodywork to check for leaks as these are usually where the musty smell comes from
Twistin me melon man
i've suceeded with this method before, i thought it was worth a try before stripping it all out.
also used that upholstery cleaning spray-foam, that helps freshen it up. and 2 or 3 goes with something like autoglym leather cleaner.
then leave the car with everything open for a couple of days (presuming you have got a safe driveway to leave it all open on)
Piss taker
i steam cleaned the inside of my landrover once didnt do it any harm just took about a month for the inside to dry out! mind you did use industrial steam cleaner! lol
Strip it out, clean, then re-fit. Job done.
Although theres no reason why you cant just steam the seats and carpet while there in. Used to do it all the time at work and works well, as long as you leave it running with the heaters on full so it can dry out properly. Usually takes a good few hours to dry fully. Dont forget to leave each front window down about 2-3 inch though so the moisture has somewhere to escape.
it also helps after a major steam clean and foaming session to put a dehumidifier in the garage with the car afterwards, obviously leave the car windows and boot open in the garage
Testing the future
Take the interior out, clean it, sort out any probs and put it back together again.
Fabreeze, Shake n Vac etc are only masking the problem and it will return within a few weeks.
Come on, do it properly.
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
