What unique parts are required to rwd an Escos?
Old 25-10-2004, 10:16 PM
SPADGE
SPADGE's Avatar
Default What unique parts are required to rwd an Escos?
Plans are a foot
I know most of the differences having changed a 4wd to 2wd before but what parts will i need to get made/altered to do the same with an Escos?
Am planning a grpA rear beam with 7.5" rear diff.
Cheers Spadge....
Old 25-10-2004, 10:43 PM
dave cos4x4
dave cos4x4's Avatar
the tunnel is a bit wider on the escort for the front diff,as i'm sure you know.
think you have to use the 4wd gearbox crossmember so it lines up with the mounts on the shell.
Dave.
Old 25-10-2004, 10:45 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
need a shortend prop, A1 rally sport could probably sort that, assuming you not fussed about hubs being 100% 2wd you can leave the 4x4 stub axels in on the fronts apparently, but don't quote me on it
Old 25-10-2004, 10:46 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
i asked this ages ago, as i was just curious, will do a search and post link
dunno if i got sensible replys tho
Old 25-10-2004, 10:48 PM
dave cos4x4
Depends what suspension/brakes you have to go on it.
Dave.
Old 25-10-2004, 11:28 PM
SPADGE
SPADGE's Avatar
Cheers for the replys fellas!
Can i not just use 2wd Cossie front hubs etc....?
Old 25-10-2004, 11:46 PM
Stu.H
Stu.H's Avatar
just get the escos 2wd and then keep it until i can afford it
might be doomsday
Old 26-10-2004, 07:27 AM
B19-TRB
B19-TRB's Avatar
Spadge man!
Am lookin @ this myself!
here's a post i found!
https://passionford.com/forum/viewto...er=asc&start=0
obviosu the prop shaft! & i aint heard about usin ther 4wd cross member b4 but some1 said to me to use the 2wd & weld a bracket onto the car for it to bolt to!
Old 26-10-2004, 07:51 AM
Mr RS500
Mr RS500's Avatar
Spadge
Just remove the complete front end running gear and swap for 2wd cossie ,,,it all goes in with no mods at all Then just have the rear prop shortened and you are away
Old 26-10-2004, 09:10 AM
SPADGE
SPADGE's Avatar
Originally Posted by NORTH YORKS RS SPARES
Spadge
Cheers Paul
This is what i thought but better to be certain then i know what i'm letting myself in for
155lee
06-09-2016 11:10 AM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
Mark V8
13-09-2015 09:34 AM
Mickeystewart
09-09-2015 04:04 PM
Quick Reply: What unique parts are required to rwd an Escos?
