how much agro to fit the works type sill tubes for stands
i do most of my own maintanance on my car etc, so being ford i spend alot of time underneath it ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
i hate having the axle stands under the car when doing certain jobs and never like where they have to be positioned on the rear on the xr2 so am thinking of fitting the sill tubes/section so i can use the rally/works type stands
how are these tubes fitted into the sill??? is a hole cut through the sill itself for the tube and then fully welded round or are they welded to the underneath of the sill/floor pan on a reinforced plate or something
any pics or info appreciated as most cars you cant see to much as the sideskirt is covering the actual position/fitting
thanks
marc
thanks
marc
most ones i do when the car is on the jig and i have a bracket that guides the hole saw so they are all the same height, otherwise its hard because the sill has a radius.
also use an extended hole saw that goes all the way through and fit strenghtener plate on th out side
https://passionford.com/forum/restorations-rebuilds-and-projects/227980-escort-stage-rally-car.html
hav a look through this and you will see my car on ady gallachers jig having had the sill mounts fitted
track.focus'd
12-08-2015 05:53 PM
