FAO auto electricians and clever folk !
where on a car can i find a relay that is always open until the switcher point is live ?
basically i have loads of old cars about and begrudge buying a relay !
could be ????
i cant think of what on a car would normally be on until a switch is thrown
i am trying to set up a cold start valve on my derv and need it to switch off when the resistance on the water temp sender reaches 0 (when up to temp) but to stay on until then
just a thought , would a dim/dip relay do that as they are "double throw" relays , just have the power going out of 1 outlet ??
i might be completely wrong though !
i really dint know what relay i need , i will be running a ignition switched live to said relay then from relay to cold start valve , i need this part of the circuit to be constantly on until the "switcher" part becomes live , this will be linked to the water temp sender so that when its up to temp there is no resistance on the switcher circuit and therefore turns off the start valve
if that makes any sense !
yeah , i ment thermo switch not sender
Ive sorted it now anyway , well sort of , need a new thermo switch as mine doesn't seem to switch now , got it so the cold start becomes active when ignition on then will cut off when its up to temp (in theory when i get a new switch)
In answer to your first post, you merely need a CHANGEOVER relay, this has TWO outputs, one is LIVE when unswitched, it then changes to the other oputput when switched, but as aid you need a thermo switch.
DavidK
27-09-2015 02:55 PM
