would pedal be softer after changing to rear discs?
Old 04-05-2008, 11:09 AM
M K
M K's Avatar
Default would pedal be softer after changing to rear discs?
i have just had a conversion done on the rear axle of the xr2 so i now run focus stub axles, handbrake,discs and calipers.
i run a wilwood bias pedal box and before fitting the rear discs the pedal was very solid, but now with the rear discs the pedal is alot softer, i have bled the brakes twice (with air pressure system) but still has alot more pedal travel before they bite, is this due to havin a bigger piston to move in the caliper than the old drum cyclinder
thanks
marc
Old 04-05-2008, 11:12 AM
Rich_w
Proven Legendary Status
Rich_w's Avatar
Yes, the calipers require more fluid movement than the old cylinders. Try fitting a bigger diameter master cylinder.
One small thing though. Are the rear pads/discs fully bedded in yet. Might be worth living with the pedal for a while see if after 200m or so it gets much better. And check all your vac lines just in case.
HTH
Old 04-05-2008, 11:14 AM
TimC
TimC's Avatar
The bigger pistons in the rear calipers will make the pedal softer as you mentioned
Old 04-05-2008, 11:25 AM
M K
M K's Avatar
thanks guys, i though it would be that,
Old 04-05-2008, 11:54 AM
Dangerous Malcolm..
Dangerous Malcolm..'s Avatar
I had the same problem when I did a RS2000 conversion on my Si. It actually failed the MOT on efficiency on the rears. I had to get a new master cylinder which was a bitch to track down but got a ATE one from Euro Car Parts. Was spot on after that.
Old 04-05-2008, 12:33 PM
costina
Live long and prosper!!
costina's Avatar
The largests bore master cylinder is 25mm and is found on a S2 turbo escort it only has 2 outlets front and rear.
I had to use one of these on my cortina with mondeo cals on front and sierra cos on rear
Worked really well after
Paul
Old 04-05-2008, 01:49 PM
M K
M K's Avatar
i am running a pedal box the so independant front and rear master cyclinders so that shouldnt need changing
Old 04-05-2008, 02:15 PM
polly_x
polly_x's Avatar
Mark, as above running the same kinda system on the Westy. Move to the next size up master cylinder. Your probably on a .62 at a guess? Try a .75
Stu
Old 04-05-2008, 06:31 PM
costina
costina's Avatar
Stu,do you have a link for pics of your car?
Paul
YODI
30-08-2015 01:12 PM
siscossie
27-08-2015 09:27 PM
cameron2
25-08-2015 07:18 AM
RsS2daz
14-08-2015 05:26 AM
Graceland
31-07-2015 10:34 AM
Quick Reply: would pedal be softer after changing to rear discs?
