Vaux people - Running Diagnosis problem
Thought I'd have a try on here, may be comparable to a Ford with same fault, and am banned from Migweb....
S plate 1600 16 valve Astra, running rough and hunting etc, stinks of fuel when you start it etc.
Diagnosed as coil, new coil, still same.
New diagnostics say coil.....
Could it be an ignition amplifier or similar?
Thanks
Thanks
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Trouble with tech2 is its a great bit of kit, even tho its way passed its sell by date, but the people using it tend to be dumbasses ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
EGR's are a major problem with them, and dont always flag a code up. Plus many vaux dealerships will rip you off for a new egr even tho they know a sps will erase the problem completly by removing the egr's software.
Rob - Couldn't hear anything.
Wasn't Vaux diagnostics, and I know for my bmw there's good and bad, bad can miss a lot.
How would it flag up coil if coil was ok?
What's got me stumped.
Runs like a pig, stinks of petrol, then will run clean for a bit, just as it should.
Matey who did second diagnostics said LT side, or ECU - may have said EGR, you know what non car people are like passing these things on...lol.
What can you do with EGR to test it's playing up at all?
Appreciate the replies!
Edit: What's sps?
Is showing insp is due, they don't look after their cars all that well...
Edit: What's sps?
Had a quick listen, but as soon as saw EML was on, told them to go get it plugged in.
Sods law, be too easy if that told you what was wrong....
Not too hot on the EGR, only had one vaux with it, old ecotec cavalier.
Where the unit bolts on or something where it leaks?
To clear the 'insp' lamp, ign off, hold trip button down and keep it held while you turn ign back on...'insp' will flash a couple times on the Astra G and then it will clear. Then get the bloody thing serviced ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
SPS is just what vauxhall call the software update facility...I cant remember what the letters sps actualy stand for and i use the function every working day lol
Its annoying me cos I had a similer thing a while back but i cant remember what I did to cure it with reference to the coil fault....
Piece if piss to check and certainly the first thing I would advise checking
You fucker ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Wish you could!
You should have seen the state of their 318, right old scrapper![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Young couple, new kid, no money etc, so trying to help.
Interesting about clearing insp light, cheers.
Wish you could!
Yeah I suppose taking it off would see state of gasket.
Does act like an airleak, hunting and sometimes ok, compensating etc, just this coil fault flagged, sounds like it's a good old vauxhall one like my ecotec and light staying on 24/7 with no faults
Zoggon
10-08-2015 10:39 AM
