pro gold hose fitting assembly guide anyone?
would just like to double check i am about to assemble my new nomex tfe lined hose and pro gold fittings correctly.
im 99.9% sure its right as cant see any other way it can be done.
here is a pic of the pro gold fitting/olive/collar and nomex covered hose
step 1 - pass the collar over the brided hose then screw the threaded olive over the exposed hose section of hose.
step 2 - push hose fitting into exposed hose end/olive
step 3 - push collar up to fitting and tighten carefully until gap between the 2 is alomost closed (i havent tightened this fully yet in the pic)
obviously applying light coating of grease or assembly lube to threads as you do with any of these types of fittings.
so is that right can anybody confirm as i dont want them leaking when in the car
thanks
marc
thanks
marc
im replacing everything in the pro gold nomex covered hose mate and pro gold fittings
will be doing it bit by bit tho over the next month or so as its very expensive @ Ł40 a meter for the hose & up to Ł35 per fitting
but a lot nicer to the eye, no fuel vapour from the hose, easier to assemble and great bend radius compared to normal aeroquip, its also roughly 20% lighter than any other fitting/hose combination, even more if you use there in house swaged fittings.
im also using JIFFY TITE dry break fittings on everything, like tank/pumps/filter/rail/regulator etc so removal is a 2 second job with no spillages etc
heres some of the dry break fittings,
it is very trick and the dry break will very rarely be needed, but handy when you want to remove stuff on the quick or if you want to drain the tank just use another length of hose with the opposite half dry break fitting and plug it in to the pump, hassle free just how i like it.
i want to do the front break lines next but there a bit dearer for the dry break fittings :blub:
na no metal in the hose mate, its just a convoluted tfe plastic material with nomex outer braid, so just like normal aeroquip wrap a bit of tape round the hose to stop it fraying and then cut with fine tooth hacksaw or fine blad dremmel cutter etc,
You flash git Marc !
I was given a load of Pro Gold fittings to finish the nova off with but after realising how much the rest would be I soon gave them back lol
The dry break fittings are awesome, had a lottery win this week or something ?
yours going to be driving to FITP, was chatting to mr field today saying neither of us has seen you in a while
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
