How much boost can i run through a 205 block +1mm rebore?
Just a simple question, safe limit i can run, it also has oversized 4x4 pistons and the engine is about 9k old
cheers, pete
cheers, pete
1 mm ? oversize pistons are either 0.25 or 0.50 i reckon that's in mm's
when u will hit full boost the crank will find its way to the tarmac and the pistons will fly trought the head in a figure of speech as the kind gent told me whilst i was on the phone with him.
as i assume its like reboring the block to 2.1 litres?
if not i am mistaken otherwise ignore it
I wouldn't put much more than standard boost through a 1mm rebore on a 205block mate, there won't be very much strength left in it at all I'm affraid
Originally Posted by ian m
i ran 2.4 bar no problems my mate also runs the same and that is + 1mm also
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Originally Posted by TIFF-C20WTH
Originally Posted by Jim Galbally
its a peice of string with a ruler next to it...
Chasing Radders
How long is a peice of string
Twice the length from the centre to the end
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
TIFF - i have a reciept with the car when the engine was rebuilt as i think it let a piston go and must have scored the bores inside, so the above is what they replaced it with, yours is standard isn't mate?
so if we rebuild our 205 block, and had it re-bored and used oversized 4x4 mahle pistons, re-ground/polished the crank ect ect ec ran it all in, and then put it back to stg3 (t34, greens, stg3 chip, 3 bar map sensor ect ect)
with a compression ratio of 8:1 what would be a sensible boost limit? 26psi?
would it all hold together?
How many times has the engine been rebuilt mate as normally people go to 0.25mm oversize, then 0.5mm...............
to answer ur other question, to rebore to a 2.1 u need 3mm ( or a bore to 93mm )oversized pistons but i dont know if u can get them for a cossie ( im sure someone would make them). i think this takes it to 2093 cc or something. but then i am going on experience from a pinto. so could advise weather safe or not on a cossie ( but i wouldnt think so ) as that is the max safe limit (although unpredicable ) of a n/a pinto. hope this helps
