When is it time to say enough is enough??
#42
Can 100% appreciate that, just thinking if it wasn't overly specialised, a decent local place could get it up and running much cheaper, and it looks like you've spent a pound or two on it!
#48
Interesting, as more often than not i see this problem on cars with fuel pump looms rewired. I would normally try:
1) Take a reading from the ISCV positive with engine running.
2) Then resisit it down to 12Volts.
This is only "IF" the problem goes away with ISCV unplugged.
It needs a high current resistor, i can post you one tomorrow if required.
#49
I will test this later.
#54
Stu, would this cause problems with mine and Jason's cars? As we all (3 of us) have the same fuel pump looms, although Jason and I are on Closed Loop and Coilpacks, without ALS & LC, but still both have ISCV problems...
Mine will not idle from cold, only once warm?
#55
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
#56
Mates cossie (standard) had idle issues, diagnosed as ICV.
New ICV, and it's unplugged, idles better without.
Is this something that affects most of them?
#57
Well how about that then same thing happened to me and its turned in to a crack. Now can you still get a heated front screen IF i do it through my insurance????
Adam Graham
06-09-2015 06:04 AM
