When is it time to say enough is enough??
Old 28-04-2008, 03:13 PM
Lo@der
Passionford Thread Killer
Lo@der's Avatar
Default When is it time to say enough is enough??
After throwing upwads of 10k and countless man hours getting flithy, frustrated or driving to collect parts or services in the last 12months.
My saff coss is still being a shit.
After changing numerous inlet parts for a few hours yesterday to no avail , (I still have an idle/ALS problem which means I will have to spend more time and money having the fault fixed at a tuner at the other end of the country) I shut my bonnet with a little to much aggresion and smashed a headlight.
So when is enough just enough?
Old 28-04-2008, 03:22 PM
Ryan
Ryan's Avatar
whats up with it mate, no idle at all? or irattic ?
bring it up if you want mate, and we can swap it with my ISCV if you want mate, as obviously its none to work.
headlight
as bad as me yesterday mate, went out for a quick blast to check the boost, and got a fucking stop chip on the window
Old 28-04-2008, 03:24 PM
Ima Racing
Ima Racing's Avatar
als and idle problems are normal unless you are using the msd als program as it retains the std iscv.
Old 28-04-2008, 03:27 PM
Turbocabbie
Top Cab !!
Turbocabbie's Avatar
I thought ALS based cars had erratic idle until warm anyway, mine most certainly does.
I believe its because of the modifications you have to do in most cases
G2RSR
Bodybuilding
G2RSR's Avatar
Location: Cannot be identified by the information given.
sorry but the problem with cosworths to many diy jobs
I mean if you bought a brand new evo working 200% spot on do you think you could strip all the engine down then rebuild it and it would be as good as it was before from the factory built from you little garage
ps im talking in general
Old 28-04-2008, 03:29 PM
Lo@der
Lo@der's Avatar
I'm running a msd setup, but its sat at 3-4k. with iscv pluged in.
Old 28-04-2008, 03:30 PM
Ryan
Ryan's Avatar
did you drive up there mate and get it all sorted ? or was the chip and parts sent down?
Lo@der
Lo@der's Avatar
headlight
Did it all yesterday swaped over iscv's, pfo9 and throttle body.
New windscreen for you then mr. bufty???
Old 28-04-2008, 03:31 PM
Porkie
Porkie's Avatar
er 10k ago...
Old 28-04-2008, 03:33 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
He is using mine mate. He got a wierd high idle problem after picking it up and this normally means 1 of 2 things.
1) Your using a modded throttle body that has been bored out too far and teh ISCV wont seal.
2) The ECU is driving teh valve as it thinks the throttle is open when its not.
Its "Normally" one of the 2.
Old 28-04-2008, 03:34 PM
Garage19
Garage19's Avatar
Have you changed the idle valve and checked it has power to it?
Have you checked your TPS is working properly? 0-5v.
If you have no air leaks then it can only be the chip keeping the valve open at the wrong time? Which would be strange as by the sounds of it stu doesn't normally make that kind of mistake.
Old 28-04-2008, 03:35 PM
Lo@der
Lo@der's Avatar
All was done at Msd, with live map.
I very much doubt its a error by msd. top fellas.
Old 28-04-2008, 03:36 PM
Garage19
Garage19's Avatar
looks like there were 3 more people that can type quiker than me! doh
Old 28-04-2008, 03:38 PM
Garage19
Garage19's Avatar
Got to be an air leak then.
Do you have a compressor that you can use to pressurise your system and then put a bit of fairy liquig in a squirty bottle and squirt round all joints / fittongs / gaskets etc.
Old 28-04-2008, 03:39 PM
Lo@der
Lo@der's Avatar
I've got one more throttle body comming to try, then its a call to you guys again I think.
cheers.
Ryan
Ryan's Avatar
as stu has said is the deffo set up correctly? i.e not part open when the throttle is shut.
Old 28-04-2008, 03:40 PM
Lo@der
Lo@der's Avatar
Done mate.
Old 28-04-2008, 03:41 PM
Lo@der
Lo@der's Avatar
Checked the tps then tryed fitting a new one , if thats what you mean.
Old 28-04-2008, 03:44 PM
Agreed, however, it worked all the way home and while we had it, although once we had a high idle and couldnt trace it, then it dissapeared when we changed the idle valve so we presumed it was that, so we know its not the software. All very odd and bad news for Nick sadly.
Old 28-04-2008, 03:45 PM
Ryan
Ryan's Avatar
yeah basically to check the voltage/resistance readings to check the throttle position is correct when the throttle is shut.
Old 28-04-2008, 03:49 PM
Lo@der
Lo@der's Avatar
Would it not show wrong on my secs monitor if it was??
Old 28-04-2008, 03:55 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Would IAW Monitor show the fault Stu ?
Old 28-04-2008, 03:58 PM
Lo@der
Lo@der's Avatar
Dan told me you had one of these, could be bringin the saff to pick up that cage then???
Old 28-04-2008, 04:01 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Or i can come your way mate I have some parts to collect from Ryan, Matcos, RobbieG, Jaycos so need to come your way soon Will ask Trev later where the laptop is
Old 28-04-2008, 04:03 PM
Lo@der
Lo@der's Avatar
Just let me know what beers you drink.
Old 28-04-2008, 04:07 PM
Ryan
Ryan's Avatar
yeah it would mate, forgot you had a monitor.
Old 28-04-2008, 04:15 PM
Garage19
Garage19's Avatar
My money is on some sort of air leak if its changable. Some air leaks air leaks only appear once the engine is hot and some only under certain vacum conditions.
Old 28-04-2008, 04:16 PM
In Theory, yes. In reality, no, not always. Ive seen various resistance problems cause this problem and in some cases had to fit a ballast resistor into the ISCV power supply to cure it.
Old 28-04-2008, 04:31 PM
Lo@der
Lo@der's Avatar
Do you think this fault could be cured in a day in reality?
I realise this could be askin the length of a piece string.
Old 28-04-2008, 04:41 PM
How long is a... oh? you pre empted that one.
Ryan
Ryan's Avatar
i got ballast resistor here if needed mate.
just let me know, you could pop up here when richie is coming down there get the IAW and also some tests on it to see if we can sort it,
Old 28-04-2008, 04:46 PM
Lo@der
Lo@der's Avatar
Though so.
Old 28-04-2008, 04:48 PM
Lo@der
Lo@der's Avatar
Got one more throttle body and iscv(both mountune) to try.
Old 28-04-2008, 04:51 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
We'll get the bully boy Saffs to beat up your bufty 3 door
Old 28-04-2008, 04:52 PM
Ryan
Ryan's Avatar
Old 28-04-2008, 04:55 PM
Lo@der
Lo@der's Avatar
lol
Old 28-04-2008, 04:57 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
lol
Yours can spit flames at it
Well maybe
Sorry Back on topic.
Old 28-04-2008, 05:01 PM
Lo@der
Lo@der's Avatar
Well maybe
Only if its fixed, or it will just anoy it with its high revving.
C4llyT
C4llyT's Avatar
Tremona in Soton no good, before trekking across country?
Just thinking to save money, and see you're local.
Not read whole thread though...
All the best with it.
Old 28-04-2008, 05:02 PM
Ryan
Ryan's Avatar
probably spit oil
and yours can spit gearbox teeth
i'll run for cover now
Quick Reply: When is it time to say enough is enough??
