How much are solid lifters??
Old Oct 24, 2004 | 05:58 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default How much are solid lifters??
as title for a YB engine do they need special cams or are they interchangable?
Old Oct 24, 2004 | 05:59 PM
GARETH T's Avatar
GARETH T
solid lifters need different cam profiles
why do you need solid lifters
Old Oct 24, 2004 | 06:00 PM
RWD_cossie_wil
8600RPM GARETH T
Old Oct 24, 2004 | 06:11 PM
GARETH T's Avatar
GARETH T
Old Oct 24, 2004 | 06:15 PM
abdr500's Avatar
abdr500
go for solid as the hydrolic dont last long i know what you mean ring burtons in ilford they ve got them
Old Oct 24, 2004 | 06:48 PM
Porkie's Avatar
Porkie
Errrrrrrr..... thats not what I thought.
Old Oct 24, 2004 | 06:50 PM
CozzyBrom's Avatar
CozzyBrom
thats right pork chop mine are fuked after 3 track dayz with 8800 rpm but got my new solids going in next week with secret cams
Old Oct 24, 2004 | 06:54 PM
Porkie's Avatar
Porkie
oh right, yes if you rev them that high I can kinda understand. But I thought that solids need reshimming every now and again. Where as Hydaulic lifters go on alot longer in a normal sub 8k rev limit engine.
I like my solids, they sound cool
Old Oct 24, 2004 | 06:55 PM
RWD_cossie_wil
soo, any ideas on HOW MUCH THEY COST?? how long do they last in general amd how do you shim them up?? is it on the valve stem or on top of the lifter?
Old Oct 24, 2004 | 07:05 PM
Ian M's Avatar
Ian M
mondeo diesel solid lifters are what you need
CozzyBrom's Avatar
CozzyBrom
there around Ł22 each then you need shim kits and cams Ł210 each from blanks
Old Oct 24, 2004 | 07:11 PM
RWD_cossie_wil
BD16's no good then?
Old Oct 24, 2004 | 07:15 PM
CozzyBrom's Avatar
CozzyBrom
no they not you need them in solid profile due to the run up ramps the profiles on cams are diffant
Old Oct 24, 2004 | 07:23 PM
RWD_cossie_wil
Old Oct 24, 2004 | 07:25 PM
Porkie's Avatar
Porkie
Sound really hardcore when revving, just do it!
Old Oct 24, 2004 | 07:27 PM
RWD_cossie_wil
doing my head in, I keep buying stuff then having to sell it to upgrade what they sounds like porkster??
Old Oct 24, 2004 | 07:38 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
i so want you to get your car running will
Old Oct 24, 2004 | 07:39 PM
RWD_cossie_wil
not the only 1 radders but i want it 110% before it goes anywhere
Old Oct 24, 2004 | 08:09 PM
markk's Avatar
markk
you can use solid lifters on hydraulic profiles , but not the other way round as brom says , the ramping angles are differant , tbh im having to change to solids due to the hydraulic units giving up after a good hard thrashing !!!
and also , cam profiles are better for the solid units
Old Oct 24, 2004 | 09:16 PM
Karl's Avatar
Karl
Norris Motorsport
markk,
Sorry mate you are wrong. You can't use solid lifters with a hydraulic cam profile as a hydraulic profile does not have the gentle acceleration ramps used to take up the tappet clearance due to full time tappet/lobe contact.
It's actually the other way round, you can use a solid cam profile with hydraulic lifters.
Old Oct 24, 2004 | 09:38 PM
boost mad's Avatar
boost mad
so what tappets do u need for bd16's? and y do they need shimming?
Old Oct 24, 2004 | 11:20 PM
markk's Avatar
markk
Karl,
my mistake , thinking about it , i was using solid profiles on my normally aspirated YB on hydraulics
Old Oct 25, 2004 | 04:53 AM
Fastmaul's Avatar
Fastmaul
K155MYRS
I'm gonna get some solid too's, now brom, what about the secret cams!
Old Oct 25, 2004 | 07:47 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
For people such as me who arent as technically clued up as some, wot are solid lifters, wot does it mean and y change from hydraulic. thanking you please.
Old Oct 25, 2004 | 11:11 AM
RWD_cossie_wil
it means rarther than having a "floating" type bucket arrangement, where the engine oil takes up the adjustment, the lifters are a solid lump of metal with no moving parts. It means that they dont suffer from "pump-up", which can result in piston to valve connection as when being revved hard the hydrulic follower can fill up with too much oil, hence giving the valve more lift
Old Oct 25, 2004 | 12:03 PM
CossieRich's Avatar
CossieRich
Thanks for that. I understand that perfectly.
Prickly_buzz
Dec 7, 2017 09:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
SMILER258
Sep 28, 2015 09:04 AM
