Fans not cutting in on a cozzy
Take the wires that go into the rad switch and join them together. If the fans work, its the switch or your radiator is blocked.
If they don't work, then the fault is somewhere else.
WEll last week my fans didnt cut in as they should gladly i was already @ home when it happend and i had a SECS to see the temp was getting a tad to high!
What should i check?
checked so far:
Fans are working directly (as they are now on a switch) ive checked the fuse and relay in the fusebox and they seem to be fine
switched the relay just in case with another but no luck.
Will it be the sensor in the rad then? ive checked it but not that good as i was a bit in a hurry .. how will i be able to check if its that one?
thanks people
checked so far:
thanks people
no i havent
on my fiesta when the stat opened i coudl see my temp guage drop 15 degrees or so i dont see this on my cossie
but it doesnt overheat in this cool weather cruising its running at 70-75 degree
i have let it get upto 105 degrees on my gauge and still the fans did not cut in,
i know the water will be hotter in the head but on my lats cossie it cut in a lot earlier
i have a burton power 92 degree fan switch
atm i have a switch in the car that links the 2 fan switch wires and this works fine
Chasing Radders
Rene
I had the same problem and saved all the fucking around i just replaced the whole lot
Here is the diagram i used and now they work fine
Took about 2 hours, so if i can do it anyone can
i dont use std temp guage have my after market badboy
atm i have my fan switch all wired up but i have a switch wired in to over ride should it not cut in
am looking to get an alloy rad anyways so will see if it works then
might look at changing the stat anyways
thas why i think my rad maybe blocked as it all works apart from the fan switch and i have tried 2 new ones
when i replaced it tho water came out
is there a +ve and -ve on a fan switch ? or does it not matter whch way round the wires go
my new fan switch has spade connectors on so had to cut the multiplug off
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
